Re: andy's AR Engineering motor plate
[Re: RustyM]
#2573820
11/04/18 12:17 PM
11/04/18 12:17 PM
Posts: 17,872 S.E. Michigan
ZIPPY
S.E. Michigan
No idea.
What I usually do is stack up the parts, take a caliper, open the jaws, put the pin in the hole, close the jaws to the desired stick-out and there is the length required. Probably need to round off to whatever's available. Need not be a lab quality caliper for that activity...el cheapo harbor freight or even a plastic one from the hardware store is fine.
Lacking a caliper and just wanting to measure, I'd stick a long screwdriver in the hole until it bottomed out... add however much stick-out you want, pull it out and measure with a tape, and there you go.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2573849
11/04/18 01:12 PM
11/04/18 01:12 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
No idea.
That's what I do.
[Re: RustyM]
#2573863
11/04/18 01:35 PM
11/04/18 01:35 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
so I don't have to buy one odd length stud I mill that position of pump to the same height as the others. since im not using power strg its ok.
JAKES AUTOMOTIVE
[Re: RustyM]
#2574561
11/05/18 08:07 PM
11/05/18 08:07 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Anyone know what length ARP studs to get for Andy's motor plate/ RB BLOCK / , 440 Source alum water pump housing?
Thanks Pretty sure they are 3.5" for the longest ones and 2.5 for the short ones. iirc
[Re: dthemi]
#2574656
11/05/18 11:44 PM
11/05/18 11:44 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
Just a suggestion,
Don't use gaskets with a motor plate. Use silicone rtv, and tighten it as tight as you like. Using gaskets, you can only tighten the plate up so tight before the gaskets get pushed out. Chassis flex will get them one day too. I wish I read this a couple weeks ago! Thanks!
[Re: dthemi]
#2575015
11/06/18 08:05 PM
11/06/18 08:05 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
Just a suggestion,
Don't use gaskets with a motor plate. Use silicone rtv, and tighten it as tight as you like. Using gaskets, you can only tighten the plate up so tight before the gaskets get pushed out. Chassis flex will get them one day too. Actually I o-ring the plate to the block - solves all the problems.
[Re: RustyM]
#2575484
11/07/18 07:08 PM
11/07/18 07:08 PM
Posts: 566 Texas
RustyM
Texas
[Re: RustyM]
#2575602
11/07/18 11:30 PM
11/07/18 11:30 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
MarkZ528, that is a great idea!!
I agree with dthemi, RTV, no gaskets. The one time I tried gaskets it bit me in the burnout box.
I use one all-thread stud on each side of the water pump to help hold and align everything on assembly. Then the rest I just measure for bolts.
I also used 'Rivnuts' to mount the motor plate brackets to the frame, worked great on my mid 10 sec Duster.
[Re: RustyM]
#2576176
11/09/18 02:15 AM
11/09/18 02:15 AM
rowin4
As for O-ring plates, Andy , maybe you could offer it as a option? On the gaskets, Years ago with elephant ears the gaskets would start leaking after a short time due to the engine torquing the plates back and forth.. I have never had a gasket leak on Andy's motor plates on either car. I use stock FelPro water pump gaskets.
