To hollow cat., or not? #257290
03/17/09 05:47 PM
03/17/09 05:47 PM
Anonymous OP
Anonymous OP
I have a 94 5.9 V8 in my truck. I think my catalytic converter is clogged, so I kind of want to hollow it out, because its not as loud as I think it should be, and open up. I'm afraid of triggering the O2 sensor or loosing back pressure, therefore losing power. What do you guys think I should do?
Re: To hollow cat., or not? #257291
03/17/09 06:01 PM
03/17/09 06:01 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
So have it checked
It will...
If you want loud get a louder muffler
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: To hollow cat., or not? [Re: HealthServices] #257292
03/17/09 06:05 PM
03/17/09 06:05 PM
Anonymous OP
Anonymous OP
Its in the garage with no transmission. I already have a custom Magnaflow exhaust from the cat back. I am also running headers. Not saying I want it louder, but my father in law was running the same system with manifolds, and was louder. Anyone else hollow the cat, or replace it with a straight pipe, or aftermarket piece?
Re: To hollow cat., or not? #257293
03/17/09 06:08 PM
03/17/09 06:08 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Do you have to pass an EMISSIONS TEST ??? You can't just hollow it out . Mopar cats do clog , replace it , get a hi flow cat if you want more flow .
Re: To hollow cat., or not? [Re: JohnRR] #257294
03/17/09 06:31 PM
03/17/09 06:31 PM
Anonymous OP
Anonymous OP
No emissions on a 94.
Re: To hollow cat., or not? [Re: JohnRR] #257295
03/17/09 06:35 PM
03/17/09 06:35 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
If you have to deal with emissions, get a high flow cat.
If there's an Oxygen sensor after the cat more than likely it's going to trip a fault code if you eliminate the cat.
Factory Mopar cats are fairly restrictive so any aftermarket cat will probably flow more especially if you get a high flow one.
If you want it louder you alot of people leave on the cat and get rid of the muffler. It gives you a throaty glass pack like sound, but not as raspy.
Re: To hollow cat., or not? [Re: SNK-EYZ] #257296
03/17/09 07:03 PM
03/17/09 07:03 PM
Anonymous OP
Anonymous OP
So getting rid of it all together is no good? Lose hp?
Re: To hollow cat., or not? #257297
03/17/09 07:39 PM
03/17/09 07:39 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Replace it with a DynoMax Super Converter or similar and be done with it.
Re: To hollow cat., or not? #257298
03/17/09 08:07 PM
03/17/09 08:07 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
no cat wont pass NYS inspection.
Re: To hollow cat., or not? #257299
03/17/09 08:10 PM
03/17/09 08:10 PM
Kirkland, Washington
Pacnorthcuda Offline
Hollow it out. I've run test pipes on two different cars with success. At least give it a shot. JMO
Re: To hollow cat., or not? [Re: Pacnorthcuda] #257300
03/17/09 08:40 PM
03/17/09 08:40 PM
JohnRR Offline
JohnRR  Offline
But if it trips a check engine fault and they connect a machine to the truck like they do in other states that have commiefornia emissions stds , NY is one i think , it will not pass , they see the light it fails .
Or in some states it's a visual , they look under the truck , NO cat , no pass .
but it's good for you to give the answer the OP is FISHING for ...
Re: To hollow cat., or not? [Re: JohnRR] #257301
03/17/09 08:46 PM
03/17/09 08:46 PM
I am sorry---what part did you or I miss? He said "no emissions on a 94". (????)
Re: To hollow cat., or not? [Re: Pacnorthcuda] #257302
03/17/09 08:53 PM
03/17/09 08:53 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
No emissions test for '95 and older in NY state. Still, I suggest you replace it with a high-flow aftermarket cat-con. For $60, your sensors will be happy, you'll be happy, and Mother Earth will be happy.
Re: To hollow cat., or not? [Re: Pacnorthcuda] #257303
03/17/09 08:53 PM
03/17/09 08:53 PM
Is there a SEPARATE visual inspection from the "emission-test" requirement?
Re: To hollow cat., or not? [Re: Pacnorthcuda] #257304
03/17/09 08:55 PM
03/17/09 08:55 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Metro NYC testing is done with a "sniffer". Upstate is just a visual, if its there physically its ok. Pre '96 does not require NYSVIP to be plugged into vehicle (OBD II only, 96 and later).
Check engine light can not be on.
Re: To hollow cat., or not? [Re: teflon] #257305
03/17/09 08:57 PM
03/17/09 08:57 PM
remove check engine light
there are ways around 'the man'
Re: To hollow cat., or not? [Re: Pacnorthcuda] #257306
03/17/09 09:03 PM
03/17/09 09:03 PM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
If the check engine light does not come on initial key to run position (i.e. bulb check) it fails!!!
Re: To hollow cat., or not? [Re: Pacnorthcuda] #257307
03/17/09 09:06 PM
03/17/09 09:06 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
With a 94 it is unlikely that the engine light will come on. I had a 96 full size that the cat had failed completely on(chamber was empty) and no light on.
I agree for 60 bucks just replace it. No fear of future emmisions hassels, and better for resale.
It won't lose you or gain you any power either way. Modern cats flow quite well.
I will ad, I worked on a 03 explorer at work today. It needs cats too. Nearly 1200 cdn for the cats alone. I can see trying tio find a way around that, but not around 60 to 200 bucks
Re: To hollow cat., or not? [Re: teflon] #257308
03/17/09 09:07 PM
03/17/09 09:07 PM
I knew that was coming---take your chances. Given the people I see in Washington administering these "tests" its worth a shot.
And the flip side, TRY hollowing out the cat--if the light comes on, BUY a new cat. A no-dollar attempt at the idea.
cajones
Re: To hollow cat., or not? #257309
03/17/09 09:42 PM
03/17/09 09:42 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
since you dont have emissions, remove the cat and dont worry about it. If you pop a code for the cat then take your rear most o2 sensor and put it in the frame rail. It just looks for clean air, and that will trick the computer to thinking you have a cat on there. I wont say how I know this.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
