To hollow cat., or not?
#257290
03/17/09 05:47 PM
03/17/09 05:47 PM
I have a 94 5.9 V8 in my truck. I think my catalytic converter is clogged, so I kind of want to hollow it out, because its not as loud as I think it should be, and open up. I'm afraid of triggering the O2 sensor or loosing back pressure, therefore losing power. What do you guys think I should do?
Re: To hollow cat., or not?
[Re: HealthServices]
#257292
03/17/09 06:05 PM
03/17/09 06:05 PM
Its in the garage with no transmission. I already have a custom Magnaflow exhaust from the cat back. I am also running headers. Not saying I want it louder, but my father in law was running the same system with manifolds, and was louder. Anyone else hollow the cat, or replace it with a straight pipe, or aftermarket piece?
#257293
03/17/09 06:08 PM
03/17/09 06:08 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
Do you have to pass an EMISSIONS TEST ??? You can't just hollow it out . Mopar cats do clog , replace it , get a hi flow cat if you want more flow .
[Re: JohnRR]
#257294
03/17/09 06:31 PM
03/17/09 06:31 PM
[Re: JohnRR]
#257295
03/17/09 06:35 PM
03/17/09 06:35 PM
Posts: 10,164 A Red State
SNK-EYZ
A Red State
If you have to deal with emissions, get a high flow cat. If there's an Oxygen sensor after the cat more than likely it's going to trip a fault code if you eliminate the cat.
Factory Mopar cats are fairly restrictive so any aftermarket cat will probably flow more especially if you get a high flow one.
If you want it louder you alot of people leave on the cat and get rid of the muffler. It gives you a throaty glass pack like sound, but not as raspy.
[Re: SNK-EYZ]
#257296
03/17/09 07:03 PM
03/17/09 07:03 PM
So getting rid of it all together is no good? Lose hp?
#257297
03/17/09 07:39 PM
03/17/09 07:39 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
Replace it with a DynoMax Super Converter or similar and be done with it.
#257298
03/17/09 08:07 PM
03/17/09 08:07 PM
Posts: 17,862 albany ny
05dakota
albany ny
no cat wont pass NYS inspection.
#257299
03/17/09 08:10 PM
03/17/09 08:10 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
No emissions on a 94.
Hollow it out. I've run test pipes on two different cars with success. At least give it a shot. JMO
[Re: Pacnorthcuda]
#257300
03/17/09 08:40 PM
03/17/09 08:40 PM
JohnRR
But if it trips a check engine fault and they connect a machine to the truck like they do in other states that have commiefornia emissions stds , NY is one i think , it will not pass , they see the light it fails .
Or in some states it's a visual , they look under the truck , NO cat , no pass .
but it's good for you to give the answer the OP is FISHING for ...
[Re: JohnRR]
#257301
03/17/09 08:46 PM
03/17/09 08:46 PM
Pacnorthcuda
I am sorry---what part did you or I miss? He said "no emissions on a 94". (????)
[Re: Pacnorthcuda]
#257302
03/17/09 08:53 PM
03/17/09 08:53 PM
In_The_Pink
Milwaukee, WI
No emissions test for '95 and older in NY state. Still, I suggest you replace it with a high-flow aftermarket cat-con. For $60, your sensors will be happy, you'll be happy, and Mother Earth will be happy.
[Re: teflon]
#257305
03/17/09 08:57 PM
03/17/09 08:57 PM
Pacnorthcuda
Metro NYC testing is done with a "sniffer". Upstate is just a visual, if its there physically its ok. Pre '96 does not require NYSVIP to be plugged into vehicle (OBD II only, 96 and later). Check engine light can not be on.
remove check engine light there are ways around 'the man'
[Re: Pacnorthcuda]
#257307
03/17/09 09:06 PM
03/17/09 09:06 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
With a 94 it is unlikely that the engine light will come on. I had a 96 full size that the cat had failed completely on(chamber was empty) and no light on. I agree for 60 bucks just replace it. No fear of future emmisions hassels, and better for resale. It won't lose you or gain you any power either way. Modern cats flow quite well. I will ad, I worked on a 03 explorer at work today. It needs cats too. Nearly 1200 cdn for the cats alone. I can see trying tio find a way around that, but not around 60 to 200 bucks
