Re: What kind of 727 speedo cable is this & what are my options?
[Re: radar]
#2571482
10/30/18 10:22 AM
10/30/18 10:22 AM
Posts: 1,682 Philadelphia
radar
Philadelphia
[Re: radar]
#2573488
11/03/18 03:24 PM
11/03/18 03:24 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
real early ones use a different style altogether, not interchangeable with either of the later styles, it's smaller. I want to say that when the stopped making the cable shifted TF was when they quit using the older, smaller style. So 65 and back?
[Re: Supercuda]
#2573534
11/03/18 06:21 PM
11/03/18 06:21 PM
Posts: 3,069 Michigan
A727Tflite
real early ones use a different style altogether, not interchangeable with either of the later styles, it's smaller. I want to say that when the stopped making the cable shifted TF was when they quit using the older, smaller style. So 65 and back? Correct. 1965 and earlier had the small opening in the extension housing and there was no “adapter” used, the cable end had a plug design that fit in the opening. 1966 was the first year for the adapter which allowed greater range of pinion tooth counts just by simply replacing the pinion shaft and gear assembly.
