Holley Dominator Fuel Pumps
#2568686
10/24/18 01:00 AM
10/24/18 01:00 AM
Posts: 2,179 California, USA
blairboy3
California, USA
Any of you guys have experience with or use these pumps? Specifically the 1200, 1400, or 1600 models that are 2 pumps in one housing? Looking for an EFI rated pump that doesn't cost an arm & a leg.
1968 Plymouth Fury III 4-Door: 12.79 @ 115, 60'- 1.93 (Hey... it's a Cruise ship... what do you expect?!) Famoso Raceway, 02/08
Re: Holley Dominator Fuel Pumps
[Re: blairboy3]
#2568696
10/24/18 01:32 AM
10/24/18 01:32 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I have never run one but I have heard mixed reviews. I have had good luck with the Walboro/TI GLS392 255LPH pumps. I run two of them in parallel staged by the EFI controller. You can find them from $80-120 each but be careful as there is knock off ones out there on eBay.
68 Barracuda Formula S 340
[Re: blairboy3]
#2568715
10/24/18 03:00 AM
10/24/18 03:00 AM
blairboy3
California, USA
My engine only makes around 400hp... maybe 450. I have a small 250hp nitrous kit on it. I bought a FiTech Meanstreet EFI kit off a buddy of mine. Brand new, only mounted to an engine for mock-ups. Those support up to 800hp (says the mf'r info), so it should be more than enough for my Fury.
[Re: blairboy3]
#2569203
10/25/18 01:10 AM
10/25/18 01:10 AM
blairboy3
California, USA
Yeah... pretty much a street car. I race it once in a blue moon. But, it's definitely not a daily driver, either. I'll see how much a new tank & in-tank pump will run.
[Re: blairboy3]
#2569241
10/25/18 07:38 AM
10/25/18 07:38 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
The dominator pumps are nothing more than billet housings that hold two in tank pumps. It’s an expensive, yet simple means of mounting a set of in- tank style pumps.
