Go Wing paint? #2568333
10/23/18 01:38 PM
10/23/18 01:38 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Ordered a concours wing from Dantes. It comes in black primer... Correct paint is organsal..??
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Go Wing paint? [Re: JMCFAN] #2568334
10/23/18 01:40 PM
10/23/18 01:40 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Organisol. Lot of different ways to get a very CLOSE finish, fewer that are absolutely correct.
Re: Go Wing paint? [Re: Pacnorthcuda] #2568368
10/23/18 02:27 PM
10/23/18 02:27 PM
WV
Little Detroit Offline
WV
actually , the wing is not supposed to be painted, if your want to be absolutely correct original. however if the finish is not acceptable you have 2 choices, either paint it with whatever satin or semi gloss single stage paint( clear will make it glossy.) or you carefully wet sand the plastic with 1500,2000,2500,AND THEN polish the plastic wing until you receive the finish you desire.depending on the "original " detail you desire , be careful when sanding away any molding seams if you are looking for oem detail. just my version, but if no repairs are needed then wet sand and polish is my best thought, but then again im seeing what you are seeing.
Re: Go Wing paint? [Re: Pacnorthcuda] #2568476
10/23/18 05:50 PM
10/23/18 05:50 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Like...?
Re: Go Wing paint? [Re: JMCFAN] #2568499
10/23/18 06:30 PM
10/23/18 06:30 PM
Like...?
Well, many years ago I tried a PPG formula for Organisol that uses a certain percentage of a flattening agent and a grit additive---I didn't like it. I ended up spraying samples of rattle can semi gloss, semi flat, satin etc looking for something I liked.
Eventually I used Total Auto's rattle can product (kinda spendy, for cans, but their stuff is very much a specialty product) and was pleased with the result.
Re: Go Wing paint? [Re: Little Detroit] #2568568
10/23/18 09:04 PM
10/23/18 09:04 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
So leave in supplied black primer..?
Re: Go Wing paint? [Re: JMCFAN] #2568625
10/23/18 10:24 PM
10/23/18 10:24 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
I would use SEM trim black or SEM hot rod black....if you mist the last 2 coats on from a distance it will give you some texture. Original organosol is tricky to lay down. If you get the texture too rough it is hard to clean. It will catch a microfiber towel and leave a mess. twocents
Re: Go Wing paint? [Re: Little Detroit] #2568677
10/24/18 12:36 AM
10/24/18 12:36 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I was under the impression the GO WING (70-early 71 application) is painted, and the GULL WING (71 application) is "smooth" as molded plastic finish?
Re: Go Wing paint? [Re: DAYCLONA] #2568697
10/24/18 01:35 AM
10/24/18 01:35 AM
WV
WV
you are correct ,im just used to working with 71's I misspoke my apologies.
Re: Go Wing paint? [Re: Little Detroit] #2568814
10/24/18 12:32 PM
10/24/18 12:32 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Should have specified early... mine is for 70 Roadrunner
