Go Wing paint?
#2568333
10/23/18 01:38 PM
10/23/18 01:38 PM
Posts: 2,087 New Mexico
JMCFAN
New Mexico
Ordered a concours wing from Dantes. It comes in black primer... Correct paint is organsal..??
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: Go Wing paint?
[Re: Pacnorthcuda]
#2568476
10/23/18 05:50 PM
10/23/18 05:50 PM
JMCFAN
New Mexico
Organisol. Lot of different ways to get a very CLOSE finish, fewer that are absolutely correct. Like...?
Re: Go Wing paint?
[Re: JMCFAN]
#2568499
10/23/18 06:30 PM
10/23/18 06:30 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Organisol. Lot of different ways to get a very CLOSE finish, fewer that are absolutely correct. Like...? Well, many years ago I tried a PPG formula for Organisol that uses a certain percentage of a flattening agent and a grit additive---I didn't like it. I ended up spraying samples of rattle can semi gloss, semi flat, satin etc looking for something I liked. Eventually I used Total Auto's rattle can product (kinda spendy, for cans, but their stuff is very much a specialty product) and was pleased with the result.
Re: Go Wing paint?
[Re: Little Detroit]
#2568568
10/23/18 09:04 PM
10/23/18 09:04 PM
JMCFAN
New Mexico
actually , the wing is not supposed to be painted, if your want to be absolutely correct original. however if the finish is not acceptable you have 2 choices, either paint it with whatever satin or semi gloss single stage paint( clear will make it glossy.) or you carefully wet sand the plastic with 1500,2000,2500,AND THEN polish the plastic wing until you receive the finish you desire.depending on the "original " detail you desire , be careful when sanding away any molding seams if you are looking for oem detail. just my version, but if no repairs are needed then wet sand and polish is my best thought, but then again im seeing what you are seeing. So leave in supplied black primer..?
Re: Go Wing paint?
#2568677
10/24/18 12:36 AM
10/24/18 12:36 AM
Posts: 18,157 Mass
DAYCLONA
Mass
actually , the wing is not supposed to be painted, if your want to be absolutely correct original. however if the finish is not acceptable you have 2 choices, either paint it with whatever satin or semi gloss single stage paint( clear will make it glossy.) or you carefully wet sand the plastic with 1500,2000,2500,AND THEN polish the plastic wing until you receive the finish you desire.depending on the "original " detail you desire , be careful when sanding away any molding seams if you are looking for oem detail. just my version, but if no repairs are needed then wet sand and polish is my best thought, but then again im seeing what you are seeing. I was under the impression the GO WING (70-early 71 application) is painted, and the GULL WING (71 application) is "smooth" as molded plastic finish?
Re: Go Wing paint?
#2568814
10/24/18 12:32 PM
10/24/18 12:32 PM
JMCFAN
New Mexico
Should have specified early... mine is for 70 Roadrunner
