Window Mechanism Grease #2568191
10/23/18 02:55 AM
10/23/18 02:55 AM
Mesa, Arizona
dart4forte Online boogie OP
dart4forte  Online Boogie OP
Mesa, Arizona
Need to lube up my window mechanisms. Any grease recommendations?
Abe Lincoln
Re: Window Mechanism Grease [Re: dart4forte] #2568200
10/23/18 04:37 AM
10/23/18 04:37 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
One of the guys here turned me on to a fantastic productitsan industrial lube called Castle Endura. It sprays on wet like WD40 and once it hits the air it gets thick and tacky. Great for hard to reack areas like those mechanisms.
I’m listening.
Re: Window Mechanism Grease [Re: Big Bad Bee] #2568202
10/23/18 04:53 AM
10/23/18 04:53 AM
Mesa, Arizona
Mesa, Arizona
Cool, just checked Amazon. Think I’ll order a can. Thanks for the tip. up
Abe Lincoln
Re: Window Mechanism Grease [Re: dart4forte] #2568260
10/23/18 10:55 AM
10/23/18 10:55 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I usually try and avoid most of the greases, esp white lithium,as they "cake" with age, I use cam moly lube on the rollers/regs, and dry graphite spray on all the slides... after a through cleaning/repair/replacement of all the reciprocating window mechanisms
Re: Window Mechanism Grease [Re: DAYCLONA] #2568284
10/23/18 12:08 PM
10/23/18 12:08 PM
Mesa, Arizona
Mesa, Arizona
Yeah, appears that someone used lithium at one time. All caked up.
Abe Lincoln
Re: Window Mechanism Grease [Re: dart4forte] #2568307
10/23/18 12:50 PM
10/23/18 12:50 PM
cbusters Offline
cbusters  Offline
I use Super Lube. Doesn't cake up, rinse off or have an issue with temperature.
Re: Window Mechanism Grease [Re: dart4forte] #2568456
10/23/18 05:21 PM
10/23/18 05:21 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I just happened upon "Fifth Wheel Grease" in the tube once, and been using it ever since. It's great. Very silky, doesn't need heat, and won't harden in winter. VERY silky.
Facts are stubborn things.
Re: Window Mechanism Grease [Re: dart4forte] #2572417
10/31/18 11:26 PM
10/31/18 11:26 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Don't we want to just lubricate the axle of the wheel so it spins nicely in the track. If the entire assembly is lathered up the wheel will just slide in the track instead of rolling. Possibly just overthinking this.
