#2568191 - 10/23/18 12:55 AM Window Mechanism Grease
dart4forte Offline
Loc: Mesa, Arizona
Need to lube up my window mechanisms. Any grease recommendations?
#2568200 - 10/23/18 02:37 AM Re: Window Mechanism Grease [Re: dart4forte]
Big Bad Bee Offline
Loc: Spokane, WA
One of the guys here turned me on to a fantastic productitsan industrial lube called Castle Endura. It sprays on wet like WD40 and once it hits the air it gets thick and tacky. Great for hard to reack areas like those mechanisms.
It's not a hobby. It's therapy.
#2568202 - 10/23/18 02:53 AM Re: Window Mechanism Grease [Re: Big Bad Bee]
dart4forte Offline
Loc: Mesa, Arizona
Cool, just checked Amazon. Think I’ll order a can. Thanks for the tip. up
#2568260 - 10/23/18 08:55 AM Re: Window Mechanism Grease [Re: dart4forte]
DAYCLONA Offline
Loc: Mass
I usually try and avoid most of the greases, esp white lithium,as they "cake" with age, I use cam moly lube on the rollers/regs, and dry graphite spray on all the slides... after a through cleaning/repair/replacement of all the reciprocating window mechanisms
#2568284 - 10/23/18 10:08 AM Re: Window Mechanism Grease [Re: DAYCLONA]
dart4forte Offline
Loc: Mesa, Arizona
Yeah, appears that someone used lithium at one time. All caked up.
#2568307 - 10/23/18 10:50 AM Re: Window Mechanism Grease [Re: dart4forte]
cbusters Online   content
Loc: Florida
I use Super Lube. Doesn't cake up, rinse off or have an issue with temperature.
#2568456 - 10/23/18 03:21 PM Re: Window Mechanism Grease [Re: dart4forte]
larrymopar360 Offline
Loc: Central Florida
I just happened upon "Fifth Wheel Grease" in the tube once, and been using it ever since. It's great. Very silky, doesn't need heat, and won't harden in winter. VERY silky.
Facts are stubborn things.
#2572417 - 10/31/18 09:26 PM Re: Window Mechanism Grease [Re: dart4forte]
Magnum Offline
Loc: Hamilton, Ontario Canada
Don't we want to just lubricate the axle of the wheel so it spins nicely in the track. If the entire assembly is lathered up the wheel will just slide in the track instead of rolling. Possibly just overthinking this.
25,698 Registered Members
196,735 Topics
How many US states have you been in?
by feets
01/19/19 10:12 AM
How far have you run a turned down crank
by scottb
01/19/19 10:08 AM
360 swap
by rscottick
01/19/19 09:49 AM
Thermostats designs that “fail open” experiences?
by 360view
01/19/19 09:01 AM
