Window Mechanism Grease
#2568191
10/23/18 02:55 AM
10/23/18 02:55 AM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
Need to lube up my window mechanisms. Any grease recommendations?
Abe Lincoln
Re: Window Mechanism Grease
[Re: dart4forte]
#2568200
10/23/18 04:37 AM
10/23/18 04:37 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
One of the guys here turned me on to a fantastic productitsan industrial lube called Castle Endura. It sprays on wet like WD40 and once it hits the air it gets thick and tacky. Great for hard to reack areas like those mechanisms.
I’m listening.
[Re: Big Bad Bee]
#2568202
10/23/18 04:53 AM
10/23/18 04:53 AM
dart4forte
Mesa, Arizona
One of the guys here turned me on to a fantastic productitsan industrial lube called Castle Endura. It sprays on wet like WD40 and once it hits the air it gets thick and tacky. Great for hard to reack areas like those mechanisms. Cool, just checked Amazon. Think I’ll order a can. Thanks for the tip.
Abe Lincoln
[Re: dart4forte]
#2568260
10/23/18 10:55 AM
10/23/18 10:55 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Need to lube up my window mechanisms. Any grease recommendations? I usually try and avoid most of the greases, esp white lithium,as they "cake" with age, I use cam moly lube on the rollers/regs, and dry graphite spray on all the slides... after a through cleaning/repair/replacement of all the reciprocating window mechanisms
[Re: DAYCLONA]
#2568284
10/23/18 12:08 PM
10/23/18 12:08 PM
dart4forte
Mesa, Arizona
Need to lube up my window mechanisms. Any grease recommendations? I usually try and avoid most of the greases, esp white lithium,as they "cake" with age, I use cam moly lube on the rollers/regs, and dry graphite spray on all the slides... after a through cleaning/repair/replacement of all the reciprocating window mechanisms Yeah, appears that someone used lithium at one time. All caked up.
Abe Lincoln
[Re: dart4forte]
#2568456
10/23/18 05:21 PM
10/23/18 05:21 PM
Posts: 15,823 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I just happened upon "Fifth Wheel Grease" in the tube once, and been using it ever since. It's great. Very silky, doesn't need heat, and won't harden in winter. VERY silky.
Facts are stubborn things.
[Re: dart4forte]
#2572417
10/31/18 11:26 PM
10/31/18 11:26 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
Don't we want to just lubricate the axle of the wheel so it spins nicely in the track. If the entire assembly is lathered up the wheel will just slide in the track instead of rolling. Possibly just overthinking this.
