Re: Has Anyone Else Tried Switching From a Mag To COP?
[Re: BobR]
#2567873
10/22/18 04:24 PM
10/22/18 04:24 PM
Posts: 4,457 Washington
madscientist
Washington
It's hard to beat a mag. It's that simple. I see many cars that would benefit from a mag. Convincing them the car needs is a tough sell.
[Re: BobR]
#2567976
10/22/18 08:04 PM
10/22/18 08:04 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
What fuel, what gap? Alot of people try to run to wide of a gap with cop. 100 hp/ cylinder should be around .022 . Seen meth cars run .015 with 30 psi boost.
[Re: TRENDZ]
#2568030
10/22/18 09:49 PM
10/22/18 09:49 PM
Posts: 8,165 Left Coast
BobR
Left Coast
What fuel, what gap? Alot of people try to run to wide of a gap with cop. 100 hp/ cylinder should be around .022 . Seen meth cars run .015 with 30 psi boost. Methanol with 60+ pounds of boost. We run between .010-.015. just depends.
[Re: AndyF]
#2568283
10/23/18 12:05 PM
10/23/18 12:05 PM
BobR
Left Coast
Do you know any of the guys who are running really well with COP and similar boost? There are probably only a few dozen guys in the whole country who have a handle on that sort of combo. We have a handle on the mag combo. The more I read about the operational logistics of the COP the more I wish I would have left it in the box. It's really hard to get information from other racers. Especially info that was difficult for them to obtain. I will keep asking and maybe something useful will come to my attention.
[Re: AndyF]
#2568375
10/23/18 02:47 PM
10/23/18 02:47 PM
BobR
Left Coast
Have you talked to Rich at FastManEFI? Rich has been running COP for at least 10 years on various cars. He probably has some boosted customers but I'm not sure about your level of boost.
Do you think it is an electrical issue? Just not enough amps available to fire the plugs with COP? Or do you think it is something else such as timing stability? I'd think COP would have some advantages but I guess it all depends on the details. With the amount of power you guys are building it would be difficult to run tests. From what I am beginning to understand it's the decreased duration of the spark(as compared to our 48 amp mag) that somehow can cause a lazy condition at lower RPM's. This may not be true for every combination but it seems to be with ours'.
[Re: BobR]
#2568377
10/23/18 02:49 PM
10/23/18 02:49 PM
TRENDZ
Milwaukee WI
If you want real, tested info on COP ignition, find Lance Nist. He holds several patents in ignition systems. He would be the first person i would contact for a maximized ignition.
Isn’t that Alepa Hemi from PLR running COP? Like 5200hp on meth?
[Re: AndyF]
#2568463
10/23/18 05:34 PM
10/23/18 05:34 PM
BobR
Left Coast
Spark duration can be adjusted but it might get expensive. Since you have 8 coils there is plenty of time for each coil to do its thing. But everything has to be sized correctly and there needs to be a bunch of amps available. I have very little knowledge of what it takes once you get to the high boost that you guys are running so I'm not sure if the parts you need are even available. I'd think that from a physics standpoint the COP setup would be superior but I don't know if the engineers have made it happen yet. It depends on who you ask Andy. If you ask me they haven't made it happen yet.
[Re: TRENDZ]
#2568467
10/23/18 05:37 PM
10/23/18 05:37 PM
BobR
Left Coast
Isn’t that Alepa Hemi from PLR running COP? Like 5200hp on meth? Yes. We've been 209.46 in the 1/8th at 3100 pounds. That figures to be 4600+-. Peak power doesn't seem to be the issue. It's idle thru about 4000 where we are having issues but with turbos you have to get them up on boost before anything happens.
[Re: BobR]
#2568469
10/23/18 05:40 PM
10/23/18 05:40 PM
crabman173
crabman173
Fuel Injection Enterprises sells and services every kind of mag--does mine and I love the guy--you can get enough mag to support whatever it is you are running from Mr Spud Miller there--I LOVE magnetos use one in my race car--we use alky nitro mix---
