Has Anyone Else Tried Switching From a Mag To COP? #2567868
10/22/18 04:04 PM
10/22/18 04:04 PM
Left Coast
BobR Offline OP
BobR  Offline OP
Left Coast
We tried it and, so far, are unhappy with the results. Car runs noticeably better and builds boost quicker with the mag. We're starting to think we may have done something wrong. Anyone else make the switch?
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: BobR] #2567873
10/22/18 04:24 PM
10/22/18 04:24 PM
Washington
madscientist Offline
Washington
It's hard to beat a mag. It's that simple. I see many cars that would benefit from a mag. Convincing them the car needs is a tough sell.
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: BobR] #2567877
10/22/18 04:29 PM
10/22/18 04:29 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
We went the other way MSD 7AL3 to Mag
Car runs better with the mag.
Don't have all the bells and whistles the box had but the car runs better.
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: Biginchmopar] #2567919
10/22/18 05:45 PM
10/22/18 05:45 PM
Left Coast
BobR Offline OP
BobR  Offline OP
Left Coast
Called Fueltech. They said our results are typical...worse down low then as good at higher engine speed/loads. Maybe with some combinations that works. With ours' it doesn't. With our cam, intake runner size and a couple of other things we do differently we need all the help down low that we can get. From our conversation with Fueltech(typical results and not an anomaly) it's coming off and the mag back on. Very disappointed as the COP does have some technical and weight advantages but power is first and foremost with us.
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: BobR] #2567928
10/22/18 06:08 PM
10/22/18 06:08 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
That sux. But it's why we test
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: BobR] #2567976
10/22/18 08:04 PM
10/22/18 08:04 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
What fuel, what gap? Alot of people try to run to wide of a gap with cop.
100 hp/ cylinder should be around .022 .
Seen meth cars run .015 with 30 psi boost.
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: Biginchmopar] #2568003
10/22/18 08:41 PM
10/22/18 08:41 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: TRENDZ] #2568030
10/22/18 09:49 PM
10/22/18 09:49 PM
Left Coast
BobR Offline OP
BobR  Offline OP
Left Coast
Methanol with 60+ pounds of boost. We run between .010-.015. just depends.
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: Dragula] #2568046
10/22/18 10:17 PM
10/22/18 10:17 PM
Left Coast
BobR Offline OP
BobR  Offline OP
Left Coast
Originally Posted By Dragula
One of those videos was the reason we tried to switch. Again...doesn't seem to work as well as the mag for us. Still hoping to find something we may have missed but unless we do the mag is going back on.
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: BobR] #2568055
10/22/18 10:24 PM
10/22/18 10:24 PM
AndyF Offline
AndyF  Offline
Do you know any of the guys who are running really well with COP and similar boost? There are probably only a few dozen guys in the whole country who have a handle on that sort of combo.
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: AndyF] #2568283
10/23/18 12:05 PM
10/23/18 12:05 PM
Left Coast
BobR Offline OP
BobR  Offline OP
Left Coast
We have a handle on the mag combo. The more I read about the operational logistics of the COP the more I wish I would have left it in the box. It's really hard to get information from other racers. Especially info that was difficult for them to obtain. I will keep asking and maybe something useful will come to my attention.
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: BobR] #2568289
10/23/18 12:22 PM
10/23/18 12:22 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Very interesting.
What coils are you using with the COP?
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: BobR] #2568352
10/23/18 02:02 PM
10/23/18 02:02 PM
AndyF Offline
AndyF  Offline
Have you talked to Rich at FastManEFI? Rich has been running COP for at least 10 years on various cars. He probably has some boosted customers but I'm not sure about your level of boost.
Do you think it is an electrical issue? Just not enough amps available to fire the plugs with COP? Or do you think it is something else such as timing stability? I'd think COP would have some advantages but I guess it all depends on the details. With the amount of power you guys are building it would be difficult to run tests.
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: 340Cuda] #2568371
10/23/18 02:43 PM
10/23/18 02:43 PM
Left Coast
BobR Offline OP
BobR  Offline OP
Left Coast
Originally Posted By 340Cuda
Very interesting.
The coils that came with the Fueltech. Fitspark8 and their smart coils.
https://www.fueltech.net/products/smart-ignition-coil
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: AndyF] #2568375
10/23/18 02:47 PM
10/23/18 02:47 PM
Left Coast
BobR Offline OP
BobR  Offline OP
Left Coast
From what I am beginning to understand it's the decreased duration of the spark(as compared to our 48 amp mag) that somehow can cause a lazy condition at lower RPM's. This may not be true for every combination but it seems to be with ours'.
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: BobR] #2568377
10/23/18 02:49 PM
10/23/18 02:49 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
If you want real, tested info on COP ignition, find Lance Nist. He holds several patents in ignition systems. He would be the first person i would contact for a maximized ignition.
Isn’t that Alepa Hemi from PLR running COP? Like 5200hp on meth?
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: BobR] #2568454
10/23/18 05:20 PM
10/23/18 05:20 PM
AndyF Offline
AndyF  Offline
Spark duration can be adjusted but it might get expensive. Since you have 8 coils there is plenty of time for each coil to do its thing. But everything has to be sized correctly and there needs to be a bunch of amps available. I have very little knowledge of what it takes once you get to the high boost that you guys are running so I'm not sure if the parts you need are even available. I'd think that from a physics standpoint the COP setup would be superior but I don't know if the engineers have made it happen yet.
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: AndyF] #2568463
10/23/18 05:34 PM
10/23/18 05:34 PM
Left Coast
BobR Offline OP
BobR  Offline OP
Left Coast
It depends on who you ask Andy. If you ask me they haven't made it happen yet.
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: TRENDZ] #2568467
10/23/18 05:37 PM
10/23/18 05:37 PM
Left Coast
BobR Offline OP
BobR  Offline OP
Left Coast
Yes. We've been 209.46 in the 1/8th at 3100 pounds. That figures to be 4600+-. Peak power doesn't seem to be the issue. It's idle thru about 4000 where we are having issues but with turbos you have to get them up on boost before anything happens.
Re: Has Anyone Else Tried Switching From a Mag To COP? [Re: BobR] #2568469
10/23/18 05:40 PM
10/23/18 05:40 PM
crabman173
crabman173
Fuel Injection Enterprises sells and services every kind of mag--does mine and I love the guy--you can get enough mag to support whatever it is you are running from Mr Spud Miller there--I LOVE magnetos use one in my race car--we use alky nitro mix---
