70 cuda 340 driveshaft #801694
09/14/10 10:10 PM
09/14/10 10:10 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
I checked the parts book and found two drive shafts listed for a 70 cuda 340,
2883636 which is 43.60"
and
2883769 which is 43.85"
Which one is correct? It shows they are the same for the other V8s as well.
1970 Dodge Challenger T/A
Re: 70 cuda 340 driveshaft [Re: jeff968] #801695
09/14/10 10:27 PM
09/14/10 10:27 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
approx 1/4" (.250) difference between the two shafts,...a 70 340 Cuda would only be equipped with a 8 3/4 rear,....Iwould think the difference is between 3 speed Auto and 4 speed application?
I know the shaft in my 340 Cuda/Auto is 43.625
Re: 70 cuda 340 driveshaft [Re: jeff968] #801696
09/14/10 11:14 PM
09/14/10 11:14 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Just went through a bunch of broadcast sheets for this driveshaft thread: '71 Barracuda driveshaft
The 636 is used on 383 auto & 4-spd and 440/426 auto.
The 769 is used on 340 auto & 4-spd and AAR. one "big" one "small" u-joint
They are both listed as "big" u-joint, but I am unsure of any differences.
I believe the 636 is 3.25" end to end and the 769 has a taper in the tube length.
Re: 70 cuda 340 driveshaft [Re: 6bblgt] #801697
09/14/10 11:26 PM
09/14/10 11:26 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If he has the broadcast sheet, what does it say?
AARs and some other small block applications used the small u-joint in front & the big one in the rear.
Re: 70 cuda 340 driveshaft [Re: Alaskan_TA] #801698
09/15/10 12:43 AM
09/15/10 12:43 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
2883636 drive shaft.
Re: 70 cuda 340 driveshaft [Re: Snoopy] #801699
09/15/10 08:58 PM
09/15/10 08:58 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
Barry,
The build sheet says 769. So, what other applications can you find that drive shaft? 318s?
Re: 70 cuda 340 driveshaft [Re: jeff968] #801700
09/15/10 09:15 PM
09/15/10 09:15 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
From 1970 broadcast sheets, 769 used in;
318, 340, 340-6 & 383 2bbl Barracudas / Cudas.
Re: 70 cuda 340 driveshaft [Re: Alaskan_TA] #801701
09/15/10 09:56 PM
09/15/10 09:56 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
That's a lot of Barracudas!!! Thanks Barry
Re: 70 cuda 340 driveshaft [Re: jeff968] #801702
09/15/10 09:59 PM
09/15/10 09:59 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I better clarify that a little, I meant the 318 4-speed cars.
D31 cars used a different shaft.
Re: 70 cuda 340 driveshaft [Re: Alaskan_TA] #801703
09/15/10 10:08 PM
09/15/10 10:08 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Barry, do you have any sheets that show a different driveshaft for any 340 '70 'Cuda?
Re: 70 cuda 340 driveshaft [Re: 6bblgt] #801704
09/15/10 10:10 PM
09/15/10 10:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I know I do not have many of those on file, but I can look.
Re: 70 cuda 340 driveshaft [Re: Alaskan_TA] #801705
09/15/10 10:42 PM
09/15/10 10:42 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I have 32 for BS23H0 D13, D21 & D32 cars so far, they all show 769.
Re: 70 cuda 340 driveshaft [Re: Alaskan_TA] #801706
09/16/10 11:06 AM
09/16/10 11:06 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Sheets I have:
'70 AAR 4-spd #769
'70 Challenger E61/D32 #782
'70 Challenger RT E87/D32/D53 #672
'70 Barracuda E24/D13 #772
'70 Barracuda E63/D32 #636
'70 Barracuda ragtop E44/D31 #768
'70 Barracuda E44/D31 #766
'70 Barracuda E44/D13 #772
'70 Cuda E87/D21 #775
'70 Challenger RT/SE E87/D32/A32 #667
'70 'Cuda E87/D21 #775
'70 'Cuda E63/D32 #636
'70 'Cuda E63/D21 #636
'70 'Cuda E55/D32 #769
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 70 cuda 340 driveshaft [Re: Alaskan_TA] #801707
09/16/10 02:58 PM
09/16/10 02:58 PM
Connecticut
jeff968 Offline OP
jeff968  Offline OP
Connecticut
You mean D13. And the parts book doesn't say that and neither does the build sheet.
Re: 70 cuda 340 driveshaft [Re: jeff968] #801708
09/16/10 03:03 PM
09/16/10 03:03 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
D31 (904) is shorter, so different shaft.
D13 uses the 769.
Re: 70 cuda 340 driveshaft [Re: Alaskan_TA] #801709
09/16/10 03:56 PM
09/16/10 03:56 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Are manual 3-speeds the same length as a 4-speed?
Re: 70 cuda 340 driveshaft [Re: Alaskan_TA] #801710
09/16/10 04:36 PM
09/16/10 04:36 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I'm guessing there is a long 3-spd tailshaft & a "short" a-body version?
What's up with all the "DRIVESHAFT" questions this week?
Are the following statements both TRUE?
All A/B/C/E 904s are the same length "SHORT" & there are "SHORT" 3-spd & 4-spd manual transmissions for A-bodies.
** Is "SHORT" the same dimension? **
All A/B/C/E 727s are the same length "LONG" & there are "LONG" 3-spd & 4-spd manual transmissions for B/C/E-bodies.
** Is "LONG" the same dimension? **
Re: 70 cuda 340 driveshaft [Re: Snoopy] #2565758
10/18/18 01:59 AM
10/18/18 01:59 AM
CA
gkd Offline
gkd  Offline
CA
Is the one in the photo for sale?
Re: 70 cuda 340 driveshaft [Re: 6bblgt] #2565972
10/18/18 03:15 PM
10/18/18 03:15 PM
DELAWARE
TONY_DAGOSTINO Offline
DELAWARE
What's up with all the "DRIVESHAFT" questions this week? <img src="/ubbthreads/images/graemlins/scope.gif" alt="" />
** [color:"red"]Is "SHORT" the same dimension? [/color] **
** [color:"red"]Is "LONG" the same dimension? [/color] **
Yes, to the Long question.
im not sure on the short question.
and not that this makes a difference to the driveshaft length, but, a-body 4-speeds used both the small (904) and the large (727) output shaft splines.
while all of the B+E body 4-speeds all used the large spline output shaft
