Page 1 of 4 1 2 3 4
Using a box truck as a race car hauler??? #2565574
10/17/18 08:37 PM
10/17/18 08:37 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Anybody ever use a box truck for a race car hauler? I sold my enclosed trailer and believe I can purchase a box truck and install a shower and toilet and register it as an RV to get lower RV insurance. The cost is about the same as the new enclosed trailer. What’s the downside is that you see?
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Using a box truck as a race car hauler??? [Re: 65 Hemi] #2565591
10/17/18 09:21 PM
10/17/18 09:21 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Not so easy to get a existing commercial truck registered as a RV.
The bed of your trailer is 4 feet off the ground.
The suspension on the truck is built for lot's of weight, the ride will be very rough inside the box unless you run it at max capacity. Even then the ride will suck.
Even though you might get lucky and be able to get RV plates for it and max it out with the nicest RV stuff, it will still look like a truck and the DOT will look at you all the more because you will be a hi-bred.
Why do you think it will be less insurance cost since it is a truck?
I think you will have more trouble finding insurance for it since it is a truck and you say it is a RV...coming from someone whom has had a truck RV for 16 years now.
The upside is you will have HD RV and race trailer...I like that part!
This chassis was built at freightliner as a RV chassis from new and has different features than a commercial truck to help it ride better for one.
Re: Using a box truck as a race car hauler??? [Re: 65 Hemi] #2565597
10/17/18 09:32 PM
10/17/18 09:32 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
The ride and HD factor is workable, getting past the DOT as a motor home shouldn't be ruffer than converting a school bus just not sure about the insurance.
Have a great day
Iowan
"obsolete is neat"
Re: Using a box truck as a race car hauler??? [Re: Challenger 1] #2565598
10/17/18 09:32 PM
10/17/18 09:32 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I see the height of the box as the biggest draw back. I did see a fellow use one a few years ago and he got around that problem by installing a hyd ram to the front of the truck. It was on a rotating mount, so that when he got to the track, he would pull a pin, rotate the ram vertical and raise the front of the truck 3-4 feet in the air, unload the car and set the truck back on the ground. He could also use it to help level the truck somewhat. If I remember correctly, he used a ram off of some type of heavy machinery (dozer maybe?) and the pump & controls off of a wood splitter. Worked pretty good.
Brian
Re: Using a box truck as a race car hauler??? [Re: Challenger 1] #2565603
10/17/18 09:37 PM
10/17/18 09:37 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I agree, but one item not yet mentioned, what GVW are we talking and/or air brakes? Those details will complicate your plans and on the road enforcement scrutiny, especially when outside your home state.
You thinking is fairly sound, but the constantly tightening DOT regulations may make you wish you had non descript tag along behind a PU..
Re: Using a box truck as a race car hauler??? [Re: 65 Hemi] #2565611
10/17/18 09:51 PM
10/17/18 09:51 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I’ve been looking and thinking for a while.I was told to register it as an RV I will need 4 things which include shower, toilet, electrical and plumbing. I will ad RV windows and wrap it so it looks like full body paint. This truck has a 4400# lift gate that I will use slide in ramps to extend the so the rear tires can sit on. It is also on air ride. It also has a passenger side door with steps to get in and out of so your not climbing in and out of the 4’ high box. Great input keep the info coming.
Doug
MOPAR or NO CAR!!!
Re: Using a box truck as a race car hauler??? [Re: jcc] #2565612
10/17/18 09:54 PM
10/17/18 09:54 PM
Cincinnati, Ohio
Cincinnati, Ohio
If it is registered as a motorhome, then the weight don't mater.
Anything goes if it has motorhome plates.
But like I said, I think many are under estimating being able to get those plates and the cost of insurance?
Re: Using a box truck as a race car hauler??? [Re: jcc] #2565615
10/17/18 09:58 PM
10/17/18 09:58 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I agree with the opinions given so far. I drive a box truck a few days a week at my job. The ride is rough, ( make sure truck you are looking at least has an air ride seat) , maintenance is a lot more in a truck that size, depending on GVW you will have to pull in to open DOT scales for weight, also depending on GVW you may need a CDL in N.J. its over 26,000 lbs. Depending on height you have to be aware of bridge heights.( P.S. the body on the truck in the picture looks high) DOT officers are always doing spot checks and you could be targeted, also I know around here you have to follow truck routes as some streets and roads have weight limits the list goes on and on….
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Using a box truck as a race car hauler??? [Re: 11secdart] #2565628
10/17/18 10:10 PM
10/17/18 10:10 PM
Cincinnati, Ohio
Cincinnati, Ohio
One time with my poor wife we detoured off the interstate around a major accident. She points to the right and says that was the truck route...me keeps going cause the car GPS had said so. Got to a low overpass RR and had to backup that red rigg and a 49' race trailer for 3 blocks in a small town. Embarrassing! Should listened to her and got a truck GPS right after that. We treat ours like a truck when we travel in it which has been a lot.
Re: Using a box truck as a race car hauler??? [Re: 65 Hemi] #2565630
10/17/18 10:12 PM
10/17/18 10:12 PM
Conroe , Texas
I
iapco103 Offline
iapco103  Offline
I
Conroe , Texas
I see you are in Texas , any vehicle 26,001 gvwr or over , you will need a class B license ( even for a motorhome ).
That high deck is going to be rough to load/unload, imho.
Paul
Re: Using a box truck as a race car hauler??? [Re: iapco103] #2565634
10/17/18 10:15 PM
10/17/18 10:15 PM
Cincinnati, Ohio
Cincinnati, Ohio
Pretty sure that truck above is rated at 25999 lbs just under the CDL requirement. That truck appears to be a med moving truck. 250-300hp
The 26000 or more CDL is a federal law, same in every state.
Re: Using a box truck as a race car hauler??? [Re: 65 Hemi] #2565636
10/17/18 10:18 PM
10/17/18 10:18 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
If I recall correctly when the factory teams had box trucks they had ramps inside the truck box that angled the race car up rather steeply.
Re: Using a box truck as a race car hauler??? [Re: Challenger 1] #2565655
10/17/18 10:32 PM
10/17/18 10:32 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
In Florida, DOT goes by the highest weight for enforcement/penalty, or as it weighs as it sits, as it is registered, or what the OEM door tag states, meaning, you can not register it under weight, other then for the tag costs.
In Florida I got a lot of DMV static trying to register a box truck to RV status, and decided not to continue the mods, as the it was not certain it RV status would be given.
Re: Using a box truck as a race car hauler??? [Re: 65 Hemi] #2565656
10/17/18 10:33 PM
10/17/18 10:33 PM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
I have been looking for that type of hauler but they are kind of rare. They seem to be more popular in Europe.
Re: Using a box truck as a race car hauler??? [Re: iapco103] #2565672
10/17/18 10:51 PM
10/17/18 10:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
That high deck is the killer.. I made up a
flat bed version and got rid of it in short
time.. if your car is low you will need some
real long ramps
wave
Re: Using a box truck as a race car hauler??? [Re: RTSE4ME] #2565673
10/17/18 10:52 PM
10/17/18 10:52 PM
Cincinnati, Ohio
Cincinnati, Ohio
One of the differences is the location of the truck frames, there are differences. That hauler above has low and narrow frame like a motorhome unlike a truck chassis.
Re: Using a box truck as a race car hauler??? [Re: 65 Hemi] #2565683
10/17/18 11:06 PM
10/17/18 11:06 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
It's a tempting idea, but the Oleyniks we used had beavertails and much lower rear sill (floor) height; yet the ramps still had to be at least 8 feet long and positively lock into the sill.
Very tough deal to modify the rear rails & floor to make a beavertail out of a "normal" box truck.
I've seen some moving vans that sit lower, but still iffy on load height and then there's the wheelwells.
Medium-duty truck maintenance is not like working on a pickup; stuff might last longer, but it's half again as large and seems like triple the weight!
We'd get a million miles or so out of a GMC 6500, but any wheel/tire/suspension/brake/drivetrain maintenance was a back-breaker.
Re: Using a box truck as a race car hauler??? [Re: 65 Hemi] #2565690
10/17/18 11:19 PM
10/17/18 11:19 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
The best deal for this style is the 26' U Haul truck. Lower than any box truck and most can drop down several inches in the rear. All aluminum floor. Modern GM V8 with auto/OD. I saw a racer from the west coast do this. He opted out of the sides and roll up door. Used the frame for the roll up door as an attachment for his crane.
Re: Using a box truck as a race car hauler??? [Re: topside] #2565693
10/17/18 11:24 PM
10/17/18 11:24 PM
Many early touring semi and professional SS and Pro Stock racers used box truck for hauling there cars up
No reason why you can't, Bob Mazolini used one for a short while back in the early 1980s, I think. Same thing on John Dianna, Bob "bucks up" Lambeck, Paul Rossi, Butch Leal and many other racers from division Seven shruggy
Re: Using a box truck as a race car hauler??? [Re: Cab_Burge] #2565747
10/18/18 01:32 AM
10/18/18 01:32 AM
my own world
theraif Offline
theraif  Offline
my own world
same here thought it would be cool to make one of these into a hauler
Page 1 of 4 1 2 3 4
