Using a box truck as a race car hauler???
#2565574
10/17/18 08:37 PM
10/17/18 08:37 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
Anybody ever use a box truck for a race car hauler? I sold my enclosed trailer and believe I can purchase a box truck and install a shower and toilet and register it as an RV to get lower RV insurance. The cost is about the same as the new enclosed trailer. What’s the downside is that you see?
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: Using a box truck as a race car hauler???
[Re: 65 Hemi]
#2565591
10/17/18 09:21 PM
10/17/18 09:21 PM
Challenger 1
Cincinnati, Ohio
Not so easy to get a existing commercial truck registered as a RV. The bed of your trailer is 4 feet off the ground. The suspension on the truck is built for lot's of weight, the ride will be very rough inside the box unless you run it at max capacity. Even then the ride will suck. Even though you might get lucky and be able to get RV plates for it and max it out with the nicest RV stuff, it will still look like a truck and the DOT will look at you all the more because you will be a hi-bred. Why do you think it will be less insurance cost since it is a truck? I think you will have more trouble finding insurance for it since it is a truck and you say it is a RV...coming from someone whom has had a truck RV for 16 years now. The upside is you will have HD RV and race trailer...I like that part! This chassis was built at freightliner as a RV chassis from new and has different features than a commercial truck to help it ride better for one.
[Re: 65 Hemi]
#2565597
10/17/18 09:32 PM
10/17/18 09:32 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
The ride and HD factor is workable, getting past the DOT as a motor home shouldn't be ruffer than converting a school bus just not sure about the insurance.
Have a great day Iowan
"obsolete is neat"
[Re: Challenger 1]
#2565603
10/17/18 09:37 PM
10/17/18 09:37 PM
Posts: 22,695 Bitopia
jcc
Bitopia
I agree, but one item not yet mentioned, what GVW are we talking and/or air brakes? Those details will complicate your plans and on the road enforcement scrutiny, especially when outside your home state.
You thinking is fairly sound, but the constantly tightening DOT regulations may make you wish you had non descript tag along behind a PU..
[Re: 65 Hemi]
#2565611
10/17/18 09:51 PM
10/17/18 09:51 PM
65 Hemi
San Diego CA
I’ve been looking and thinking for a while.I was told to register it as an RV I will need 4 things which include shower, toilet, electrical and plumbing. I will ad RV windows and wrap it so it looks like full body paint. This truck has a 4400# lift gate that I will use slide in ramps to extend the so the rear tires can sit on. It is also on air ride. It also has a passenger side door with steps to get in and out of so your not climbing in and out of the 4’ high box. Great input keep the info coming.
Doug
[Re: jcc]
#2565612
10/17/18 09:54 PM
10/17/18 09:54 PM
Challenger 1
Cincinnati, Ohio
If it is registered as a motorhome, then the weight don't mater.
Anything goes if it has motorhome plates.
But like I said, I think many are under estimating being able to get those plates and the cost of insurance?
[Re: jcc]
#2565615
10/17/18 09:58 PM
10/17/18 09:58 PM
Posts: 4,963 new jersey usa
11secdart
new jersey usa
I agree with the opinions given so far. I drive a box truck a few days a week at my job. The ride is rough, ( make sure truck you are looking at least has an air ride seat) , maintenance is a lot more in a truck that size, depending on GVW you will have to pull in to open DOT scales for weight, also depending on GVW you may need a CDL in N.J. its over 26,000 lbs. Depending on height you have to be aware of bridge heights.( P.S. the body on the truck in the picture looks high) DOT officers are always doing spot checks and you could be targeted, also I know around here you have to follow truck routes as some streets and roads have weight limits the list goes on and on….
[Re: 65 Hemi]
#2565636
10/17/18 10:18 PM
10/17/18 10:18 PM
Posts: 3,496 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
If I recall correctly when the factory teams had box trucks they had ramps inside the truck box that angled the race car up rather steeply.
[Re: Challenger 1]
#2565655
10/17/18 10:32 PM
10/17/18 10:32 PM
jcc
Bitopia
Pretty sure that truck above is rated at 25999 lbs just under the CDL requirement. That truck appears to be a med moving truck. 250-300hp
The 26000 or more CDL is a federal law, same in every state. In Florida, DOT goes by the highest weight for enforcement/penalty, or as it weighs as it sits, as it is registered, or what the OEM door tag states, meaning, you can not register it under weight, other then for the tag costs. In Florida I got a lot of DMV static trying to register a box truck to RV status, and decided not to continue the mods, as the it was not certain it RV status would be given.
[Re: 65 Hemi]
#2565656
10/17/18 10:33 PM
10/17/18 10:33 PM
Posts: 2,033 MD
RTSE4ME
MD
Anybody ever use a box truck for a race car hauler? I sold my enclosed trailer and believe I can purchase a box truck and install a shower and toilet and register it as an RV to get lower RV insurance. The cost is about the same as the new enclosed trailer. What’s the downside is that you see? I have been looking for that type of hauler but they are kind of rare. They seem to be more popular in Europe.
[Re: iapco103]
#2565672
10/17/18 10:51 PM
10/17/18 10:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
That high deck is the killer.. I made up a flat bed version and got rid of it in short time.. if your car is low you will need some real long ramps
[Re: RTSE4ME]
#2565673
10/17/18 10:52 PM
10/17/18 10:52 PM
Challenger 1
Cincinnati, Ohio
Anybody ever use a box truck for a race car hauler? I sold my enclosed trailer and believe I can purchase a box truck and install a shower and toilet and register it as an RV to get lower RV insurance. The cost is about the same as the new enclosed trailer. What’s the downside is that you see? I have been looking for that type of hauler but they are kind of rare. They seem to be more popular in Europe. One of the differences is the location of the truck frames, there are differences. That hauler above has low and narrow frame like a motorhome unlike a truck chassis.
[Re: topside]
#2565693
10/17/18 11:24 PM
10/17/18 11:24 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
Many early touring semi and professional SS and Pro Stock racers used box truck for hauling there cars No reason why you can't, Bob Mazolini used one for a short while back in the early 1980s, I think. Same thing on John Dianna, Bob "bucks up" Lambeck, Paul Rossi, Butch Leal and many other racers from division Seven
