vacuum or mechanical advance #256546
03/17/09 08:54 AM
03/17/09 08:54 AM
wisconsin usa
moretork03 Offline OP
wisconsin usa
Stoked 440, i think 555 cubes.any one have info on which advance I should run and the reasons?
Re: vacuum or mechanical advance [Re: moretork03] #256547
03/17/09 09:02 AM
03/17/09 09:02 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Depends on how your using the car. Is it street/strip or a 100% race only?
Re: vacuum or mechanical advance [Re: WILD BILL] #256548
03/17/09 09:30 AM
03/17/09 09:30 AM
Europa, Estonia
Georg Offline
Georg  Offline
Europa, Estonia
Exactly. When it`s street car what see race track few times use vacuum, if it`s full race car use mechanical one
Outlaw Plymouth Valiant R5/P7 Powered by Liuzzo Racing COMP Performance Group dealer in Baltic Premium Performance
Re: vacuum or mechanical advance [Re: WILD BILL] #256549
03/17/09 10:56 AM
03/17/09 10:56 AM
wisconsin usa
wisconsin usa
was race only but going to strip/street, what is advantage or disadvantage?
Re: vacuum or mechanical advance [Re: moretork03] #256550
03/17/09 10:59 AM
03/17/09 10:59 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
You always have mech advance unless you LOCKOUT the dist. , Vac advance is for fuel economy under PART THROTTLE cruising conditions .
Re: vacuum or mechanical advance [Re: JohnRR] #256551
03/17/09 01:12 PM
03/17/09 01:12 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
vac advance is for high vac conditions when a little more advance is beneficial
WAXER
Re: vacuum or mechanical advance [Re: QWK_ENUF] #256552
03/17/09 01:30 PM
03/17/09 01:30 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I just capped the vac advance on mine and use the mechanical only, works good and one less thing to worry about/fuss with.
Re: vacuum or mechanical advance [Re: Joshs68] #256553
03/17/09 02:34 PM
03/17/09 02:34 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Don't think I've run a vacuum advance on any of my mopars. well maybe my 318 coronet. All of them that had some performace upgrades have been blocked. I'm guessing you will have your distrib curved for your application?
Re: vacuum or mechanical advance [Re: JohnRR] #256554
03/17/09 02:42 PM
03/17/09 02:42 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
100% correct
A motor like that will need a custom curve on the mechanical to match the build. Cam, tire size, stall speed, weight, etc.. all play a part in the desired mechanical advance curve.
Vacuum advance is a feature for economy. Under hard throttle, performance should be unchanged, even on a mild build.
I curve deistributors on my sunn machine, and quite often will delete the vacuum. Usually on applications where the motor is radical enough the the mileage is not affected by not having it. Usually on these same apps, the initial value is so high, that adding vacuum at lower speeds gives it too much advance. Can creat a light throttle surge condition. Vacuum can also be a negative thing on a 4 gear car, as it comes up on the shifts, adding the possibility of theadvance plate sticking with too much advance etc..
Equally, on a milder build there is no reason not to run vacuum advance.
It only becomes a gray area in the middle
Re: vacuum or mechanical advance [Re: Mr.Yuck] #256555
03/17/09 02:45 PM
03/17/09 02:45 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
on my my street cars with 500" motors,i use mech advance only. i tried to use vaccum adv.but it made the car surge and sputter at a steady throttle. when i unhooked it ,it went away.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: vacuum or mechanical advance [Re: Old School] #256556
03/17/09 04:01 PM
03/17/09 04:01 PM
Northport, al.
tvt59 Offline
tvt59  Offline
Northport, al.
Don't mean to steal the tread. But I am going to try a programable msd 6 on my Valiant. Has any one else tried this?
Re: vacuum or mechanical advance [Re: dave571] #256557
03/17/09 04:48 PM
03/17/09 04:48 PM
wisconsin usa
wisconsin usa
thanks for all the info guy's.I wanted to know which distributor to get and now I know.I bought the car from a car finder, not the builder who raced it in the 80's. The car had a crossover ignition with a computer and the guy did not know how to program it so he put a points dist so I could hear it run before I purchased it.I know its a radical build, i found time slips under the carpet running low 8's.I want to go with electronic ign.
Re: vacuum or mechanical advance [Re: moretork03] #256558
03/17/09 09:22 PM
03/17/09 09:22 PM
dave571 Offline
dave571  Offline
Definately no vacuum advance on a car like that.
I doubt many 8 second cars run advance at all. More likely be a lockdown unit with a timing retard to start it.
If it has advance at all, it will be a really short curve.
Re: vacuum or mechanical advance [Re: dave571] #256559
03/17/09 10:02 PM
03/17/09 10:02 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
If it has any sort of cam in it with a big motor you want to lock it out. It will idle much better with all the timing in it.
Re: vacuum or mechanical advance [Re: dave571] #256560
03/18/09 08:35 AM
03/18/09 08:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah that, get a pro to set it up and lock it down.
Re: vacuum or mechanical advance [Re: tvt59] #256561
03/18/09 08:44 AM
03/18/09 08:44 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I haven't tried it. Too many people get pissed when you throw a curve like this in a good reading thread. Kind of like barnacles on a whale's privates. It's very irritating to the other parties involved. It's always best to start clean with your own new thread.
Re: vacuum or mechanical advance [Re: moretork03] #256562
03/18/09 11:51 AM
03/18/09 11:51 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My distributor`s been locked out for years and it starts/runs just fine and it`s one less thing to worry about..........from personal exp. the start retard made starting HARDER.....threw it in the trash years ago and starts fine w/out it.
