Et street s/s vs sportsman s/r #2564718
10/16/18 03:32 AM
10/16/18 03:32 AM
NC
70charger512 Offline OP
#1 Thread Starter
#1 Thread Starter
NC
Im planning on ditching the bfg radial t/a’s when i go to the strip. Which would be better to drive to and race at the strip, the MT et street ss or sportsman s/r? Theres really two questions here: which hooks better and which wouldnt cause too much of a problem deiving an hour there and an hour back? Also what would be the max size i could fit with stock wells in a 70 charger with a dana 60?
Re: Et street s/s vs sportsman s/r [Re: 70charger512] #2564740
10/16/18 09:18 AM
10/16/18 09:18 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I currently run the ET Street SS. Handles great on the street, even good in some pretty bad rain when they are new. They will wear quicker than a street tire, obviously...I haven't run the sportsman, but I assume they are similar to the old bias sportsman, I.e. useless at the track.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Et street s/s vs sportsman s/r [Re: OUTLAWD] #2564741
10/16/18 09:38 AM
10/16/18 09:38 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
You can get any Tire to hook if you have good prep and a good suspension.
I've ran the lowly Sportsman S/T (the one with white letters) and managed a 1.72 60 ft time. 275/60/15.
'63 Dodge 330
11.19 @ 121 mph
Re: Et street s/s vs sportsman s/r [Re: 70charger512] #2564749
10/16/18 10:00 AM
10/16/18 10:00 AM
an8sec70cuda Offline
The Sportsman SR is NOT a drag tire. Get the ET Street SS if you want it to hook.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Et street s/s vs sportsman s/r [Re: 70charger512] #2564763
10/16/18 11:03 AM
10/16/18 11:03 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I like the ET/streets.Over 1000 miles a year then her they are at 9 lbs.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Et street s/s vs sportsman s/r [Re: 70charger512] #2564771
10/16/18 11:16 AM
10/16/18 11:16 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
I had some big 31.5 x 14" Sportsman SR's on my car and they were hard as a hockey puck and didn't hook.
Re: Et street s/s vs sportsman s/r [Re: 70charger512] #2564811
10/16/18 01:32 PM
10/16/18 01:32 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
SR stands for Street Radial; not a drag tire at all, wouldn’t be any better than your T/A’s. I’d mount up a set of ET Street R radials on a set of wheels and keep them for drag strip days only. They’ll be just fine on the street for trips to the track and back. If you’re more comfortable with the SS’s they’ll work too, but if you’re only going to use them for racing, might as well go with the real race tire.
If you are thinking of just running these tires full time, be aware the compound is very soft and will wear out quickly. If you street drive the car regularly, you’ll be buying tires rapidly.
Re: Et street s/s vs sportsman s/r [Re: 70charger512] #2564861
10/16/18 02:58 PM
10/16/18 02:58 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My son just bought the M/T SS drag radials like the ones they tested in last month's Mopar Muscle on a mid 11 second Dart. We hope to get to the track this weekend but I have heard they work very good. Ron
Re: Et street s/s vs sportsman s/r [Re: 70charger512] #2564872
10/16/18 03:19 PM
10/16/18 03:19 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I run the ET street R 325-50-15 on my 68 Charger, stock wheel wells, outer lip is rolled, AWESOME street strip tire.
Re: Et street s/s vs sportsman s/r [Re: 70charger512] #2564875
10/16/18 03:22 PM
10/16/18 03:22 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
Thanks for the replies, keep them coming, but also: would the bfg ta’s be fine to run on the front?
Re: Et street s/s vs sportsman s/r [Re: 70charger512] #2564881
10/16/18 03:28 PM
10/16/18 03:28 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
yes
Re: Et street s/s vs sportsman s/r [Re: 70charger512] #2564883
10/16/18 03:31 PM
10/16/18 03:31 PM
Puyallup, WA
Puyallup, WA
Absolutely. My car is primarily a track car these days, I run M/T Sportsman S/T’s up front (nearly the same tire as a BFG T/A). No worries. The only reason to go to drag specific front tires is weight savings (they tend to be lightweight).
Re: Et street s/s vs sportsman s/r [Re: StealthWedge67] #2565001
10/16/18 06:53 PM
10/16/18 06:53 PM
iagree
Very lightweight and very thin on the sidewalls and tread, not the best tires to use on the street tsk work
That being said I ran them, M/T 2 ply lightweight ET Front drag race tires on my old pump gas Duster as well as a set of 165x15 SR on another set of rims, the radials where better on the street up
Re: Et street s/s vs sportsman s/r [Re: 70charger512] #2565022
10/16/18 07:24 PM
10/16/18 07:24 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
Im hijacking my own post: ignore the sportsman sr’s, im thinking of going with the et steet r radials, but would it be fine to drive an hour to the track and back on them? Or should i go with the s/s?
Re: Et street s/s vs sportsman s/r [Re: 70charger512] #2565030
10/16/18 07:41 PM
10/16/18 07:41 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I drive mine more than that with them.
Re: Et street s/s vs sportsman s/r [Re: StealthWedge67] #2565051
10/16/18 08:25 PM
10/16/18 08:25 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
How rapidly (assuming no show-off burnout contests?)? 500 miles? 5000? work
Re: Et street s/s vs sportsman s/r [Re: DrCharles] #2565056
10/16/18 08:37 PM
10/16/18 08:37 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
so far 2000 miles & still look new.
Re: Et street s/s vs sportsman s/r [Re: 70charger512] #2565076
10/16/18 09:10 PM
10/16/18 09:10 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Im planning on ditching the bfg radial t/a’s when i go to the strip. Which would be better to drive to and race at the strip, the MT et street ss or sportsman s/r? ......
When are you planning to go to the strip? Are you buying tires today for the stroker you decided to build yesterday, or is this for something else?
Re: Et street s/s vs sportsman s/r [Re: BSB67] #2565118
10/16/18 10:43 PM
10/16/18 10:43 PM
NC
#1 Thread Starter
#1 Thread Starter
NC
Im obviously still trying to figure the whole car out, if u couldnt figure that out. Id like to have everything planned before i build it to save myself the time and money. I also havent decided on stroking it yet.
Re: Et street s/s vs sportsman s/r [Re: 70charger512] #2565156
10/17/18 12:05 AM
10/17/18 12:05 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Okay.
