Re: Et street s/s vs sportsman s/r
[Re: 70charger512]
#2564740
10/16/18 09:18 AM
10/16/18 09:18 AM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I currently run the ET Street SS. Handles great on the street, even good in some pretty bad rain when they are new. They will wear quicker than a street tire, obviously...I haven't run the sportsman, but I assume they are similar to the old bias sportsman, I.e. useless at the track.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#2564741
10/16/18 09:38 AM
10/16/18 09:38 AM
Posts: 4,669 Wichita
GY3
Wichita
You can get any Tire to hook if you have good prep and a good suspension.
I've ran the lowly Sportsman S/T (the one with white letters) and managed a 1.72 60 ft time. 275/60/15.
[Re: 70charger512]
#2564749
10/16/18 10:00 AM
10/16/18 10:00 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
The Sportsman SR is NOT a drag tire. Get the ET Street SS if you want it to hook.
[Re: 70charger512]
#2564763
10/16/18 11:03 AM
10/16/18 11:03 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I like the ET/streets.Over 1000 miles a year then her they are at 9 lbs.
[Re: 70charger512]
#2564811
10/16/18 01:32 PM
10/16/18 01:32 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
SR stands for Street Radial; not a drag tire at all, wouldn’t be any better than your T/A’s. I’d mount up a set of ET Street R radials on a set of wheels and keep them for drag strip days only. They’ll be just fine on the street for trips to the track and back. If you’re more comfortable with the SS’s they’ll work too, but if you’re only going to use them for racing, might as well go with the real race tire. If you are thinking of just running these tires full time, be aware the compound is very soft and will wear out quickly. If you street drive the car regularly, you’ll be buying tires rapidly.
[Re: 70charger512]
#2564872
10/16/18 03:19 PM
10/16/18 03:19 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
I run the ET street R 325-50-15 on my 68 Charger, stock wheel wells, outer lip is rolled, AWESOME street strip tire.
[Re: 70charger512]
#2564881
10/16/18 03:28 PM
10/16/18 03:28 PM
CSK
Pattison Texas
Thanks for the replies, keep them coming, but also: would the bfg ta’s be fine to run on the front? yes
[Re: 70charger512]
#2564883
10/16/18 03:31 PM
10/16/18 03:31 PM
StealthWedge67
Puyallup, WA
Thanks for the replies, keep them coming, but also: would the bfg ta’s be fine to run on the front? Absolutely. My car is primarily a track car these days, I run M/T Sportsman S/T’s up front (nearly the same tire as a BFG T/A). No worries. The only reason to go to drag specific front tires is weight savings (they tend to be lightweight).
[Re: StealthWedge67]
#2565001
10/16/18 06:53 PM
10/16/18 06:53 PM
Posts: 43,119 Bend,OR USA
Cab_Burge
Thanks for the replies, keep them coming, but also: would the bfg ta’s be fine to run on the front? The only reason to go to drag specific front tires is weight savings (they tend to be lightweight). Very lightweight and very thin on the sidewalls and tread, not the best tires to use on the street That being said I ran them, M/T 2 ply lightweight ET Front drag race tires on my old pump gas Duster as well as a set of 165x15 SR on another set of rims, the radials where better on the street
[Re: 70charger512]
#2565030
10/16/18 07:41 PM
10/16/18 07:41 PM
CSK
Pattison Texas
Im hijacking my own post: ignore the sportsman sr’s, im thinking of going with the et steet r radials, but would it be fine to drive an hour to the track and back on them? Or should i go with the s/s? I drive mine more than that with them.
[Re: DrCharles]
#2565056
10/16/18 08:37 PM
10/16/18 08:37 PM
CSK
Pattison Texas
How rapidly (assuming no show-off burnout contests?)? 500 miles? 5000? so far 2000 miles & still look new.
[Re: 70charger512]
#2565076
10/16/18 09:10 PM
10/16/18 09:10 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
Im planning on ditching the bfg radial t/a’s when i go to the strip. Which would be better to drive to and race at the strip, the MT et street ss or sportsman s/r? ...... When are you planning to go to the strip? Are you buying tires today for the stroker you decided to build yesterday, or is this for something else?
[Re: BSB67]
#2565118
10/16/18 10:43 PM
10/16/18 10:43 PM
Posts: 257 NC
70charger512
#1 Thread Starter
#1 Thread Starter
NC
Im planning on ditching the bfg radial t/a’s when i go to the strip. Which would be better to drive to and race at the strip, the MT et street ss or sportsman s/r? ...... When are you planning to go to the strip? Are you buying tires today for the stroker you decided to build yesterday, or is this for something else? Im obviously still trying to figure the whole car out, if u couldnt figure that out. Id like to have everything planned before i build it to save myself the time and money. I also havent decided on stroking it yet.
[Re: 70charger512]
#2565156
10/17/18 12:05 AM
10/17/18 12:05 AM
BSB67
Prospect, PA
Im planning on ditching the bfg radial t/a’s when i go to the strip. Which would be better to drive to and race at the strip, the MT et street ss or sportsman s/r? ...... When are you planning to go to the strip? Are you buying tires today for the stroker you decided to build yesterday, or is this for something else? Im obviously still trying to figure the whole car out, if u couldnt figure that out. Id like to have everything planned before i build it to save myself the time and money. I also havent decided on stroking it yet. Okay.
