Re: Which trans pan gasket ?
[Re: 70Challengerse]
#256419
03/16/09 10:46 PM
03/16/09 10:46 PM
Posts: 1,760 Port Alberni, British Columbia
MoparDonny
buy a reusuable pan gasket Chrysler has them and some after market companies carry them..
Unless you have a new pan, that gasket will leak for sure. I've used the 3 common Chrysler gaskets and find the cork to be the most leak resistant. The re-usable MP rubber gasket works good till the pan gets a bit warped or after a couple years when the gasket becomes compressed. If you use one DO NOT OVERTIGHTEN .I have the newer type hard gasket with the dual ribs all the way around, came with my MP aluminum pan but I use it with a new MP deep steel pan. Works good for now but I always keep a cork gasket around as a failsafe.
Don.
[Re: MoparDonny]
#256420
03/16/09 10:48 PM
03/16/09 10:48 PM
Posts: 7,512 Lebanon ,PA in the Susquehanna...
70Challengerse
Don.
brown neoprene then...that works good on the older pans..
[Re: dOc !]
#256422
03/16/09 11:13 PM
03/16/09 11:13 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
the dealer carries them ...1999 dodge 1500 with 360...trans is an A518/46re...
same gasket as a 727...reuseable...
727 is 2464324ac
904 is 4295875ac
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
