Which trans pan gasket ? #256415
03/16/09 10:27 PM
03/16/09 10:27 PM
Champlin Mn.
2
2DoorPost Offline OP
Champlin Mn.
I need a trans pan gasket.What do you folks prefer,cork,rubber,or something else? Just don't want leaks!
Re: Which trans pan gasket ? [Re: 2DoorPost] #256416
03/16/09 10:30 PM
03/16/09 10:30 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline
buy a reusuable pan gasket Chrysler has them and some after market companies carry them..
Re: Which trans pan gasket ? [Re: 2DoorPost] #256417
03/16/09 10:39 PM
03/16/09 10:39 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Anything, ANYTHING but that folded up black fibery thing that sometimes comes with the filters.
Re: Which trans pan gasket ? [Re: 70Challengerse] #256418
03/16/09 10:40 PM
03/16/09 10:40 PM
Champlin Mn.
2
Champlin Mn.
Does anyone know part# for a reuseable pan gasket? It's a 727.
Re: Which trans pan gasket ? [Re: 70Challengerse] #256419
03/16/09 10:46 PM
03/16/09 10:46 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
Unless you have a new pan, that gasket will leak for sure. I've used the 3 common Chrysler gaskets and find the cork to be the most leak resistant. The re-usable MP rubber gasket works good till the pan gets a bit warped or after a couple years when the gasket becomes compressed. If you use one DO NOT OVERTIGHTEN .I have the newer type hard gasket with the dual ribs all the way around, came with my MP aluminum pan but I use it with a new MP deep steel pan. Works good for now but I always keep a cork gasket around as a failsafe.
Don.
Re: Which trans pan gasket ? [Re: MoparDonny] #256420
03/16/09 10:48 PM
03/16/09 10:48 PM
Don.
brown neoprene then...that works good on the older pans..
Re: Which trans pan gasket ? [Re: 2DoorPost] #256421
03/16/09 10:52 PM
03/16/09 10:52 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
ANY pan gasket is reusable if you treat-it-right. Just glue-it on the pan and make sure the trans is slightly oiled. It will come off every time in one piece.
The trick is ...is to have the pan-rail straight and not warped. And do NOT over-tighten the bolts ... just use light pressure on a 1/4 rachet. If the gasket starts to squeeze-out ...it is waaaay too tight.
Re: Which trans pan gasket ? [Re: BeEtLeJuIcE !] #256422
03/16/09 11:13 PM
03/16/09 11:13 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
the dealer carries them ...1999 dodge 1500 with 360...trans is an A518/46re...
same gasket as a 727...reuseable...
727 is 2464324ac
904 is 4295875ac
Tony
70 AARCuda Vitamin C
