ring gap location placement needed #2561071
10/08/18 09:10 PM
10/08/18 09:10 PM
RapidRobert Offline OP
conflickting info in several Mopar publications. 360 race app cast pistons std 5/64 3/16 3/16 moly rings (if that makes a difference). what do you guys recommend? Thank you for your time.
Re: ring gap location placement needed [Re: RapidRobert] #2561077
10/08/18 09:19 PM
10/08/18 09:19 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Lots of comments over the last 50 years...
and the answer is "after 5 minutes they do whatever they want".
Boffin Emeritus
Re: ring gap location placement needed [Re: polyspheric] #2561129
10/08/18 10:47 PM
10/08/18 10:47 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree
Robert I start with the ring makers suggestion and go from there, you might want to write down the location of all the ring placement for that motor and looked at all of them when you tear it down the next time scope twocents whistling Test, test and test some more thumbs
Re: ring gap location placement needed [Re: Cab_Burge] #2561216
10/09/18 01:15 AM
10/09/18 01:15 AM
I will do just that: I will Google the ring mfr & get their pattern (& record it, my note takeing is terrible & has bit me in the a$$ many times!) then later on see if they migrate on teardown. thanks guys.
Re: ring gap location placement needed [Re: RapidRobert] #2563019
10/12/18 05:27 PM
10/12/18 05:27 PM
Cleveland Ohio
Discoquik Offline
Discoquik  Offline
Cleveland Ohio
Usually rings just need to be clocked 45 degrees from each ring that's below it. The cross hatch in the cylinder will make the rings spins anyway so it's kinda pointless but a good practice.
Re: ring gap location placement needed [Re: RapidRobert] #2563026
10/12/18 05:54 PM
10/12/18 05:54 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I've always put the gaps between 2 and 4, and 8 and 10 o'clock looking at it from the top with 12 o'clock facing the lifter valley. Top and second at 180* apart. Oil rings 180 apart as well. From instructions I saw long ago, and thinking it will keep the gaps away from the thrust side of the pistons. Seemed to work, but I would not try to out think any guideline provided by the manufacturers.
Re: ring gap location placement needed [Re: CMcAllister] #2563228
10/13/18 02:30 AM
10/13/18 02:30 AM
I will try not to overthink this! thanks guys.
Re: ring gap location placement needed [Re: CMcAllister] #2563646
10/14/18 12:06 AM
10/14/18 12:06 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This is what I basically do with the comp rings 180 apart and the oil ring rails 180 apart. I agree they will move around when the eng runs as you see them all over when you take them apart. Ron
Re: ring gap location placement needed [Re: 383man] #2563710
10/14/18 01:50 AM
10/14/18 01:50 AM
Noted & thanks guys.
