ring gap location placement needed
#2561071
10/08/18 09:10 PM
10/08/18 09:10 PM
RapidRobert
conflickting info in several Mopar publications. 360 race app cast pistons std 5/64 3/16 3/16 moly rings (if that makes a difference). what do you guys recommend? Thank you for your time.
Re: ring gap location placement needed
[Re: RapidRobert]
#2561077
10/08/18 09:19 PM
10/08/18 09:19 PM
Posts: 4,210 New York
polyspheric
New York
Lots of comments over the last 50 years...
and the answer is "after 5 minutes they do whatever they want".
Boffin Emeritus
[Re: Cab_Burge]
#2561216
10/09/18 01:15 AM
10/09/18 01:15 AM
RapidRobert
I will do just that: I will Google the ring mfr & get their pattern (& record it, my note takeing is terrible & has bit me in the a$$ many times!) then later on see if they migrate on teardown. thanks guys.
[Re: RapidRobert]
#2563026
10/12/18 05:54 PM
10/12/18 05:54 PM
Posts: 11,658 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I've always put the gaps between 2 and 4, and 8 and 10 o'clock looking at it from the top with 12 o'clock facing the lifter valley. Top and second at 180* apart. Oil rings 180 apart as well. From instructions I saw long ago, and thinking it will keep the gaps away from the thrust side of the pistons. Seemed to work, but I would not try to out think any guideline provided by the manufacturers.
[Re: CMcAllister]
#2563228
10/13/18 02:30 AM
10/13/18 02:30 AM
RapidRobert
I will try not to overthink this! thanks guys.
[Re: CMcAllister]
#2563646
10/14/18 12:06 AM
10/14/18 12:06 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I've always put the gaps between 2 and 4, and 8 and 10 o'clock looking at it from the top with 12 o'clock facing the lifter valley. Top and second at 180* apart. Oil rings 180 apart as well. From instructions I saw long ago, and thinking it will keep the gaps away from the thrust side of the pistons. Seemed to work, but I would not try to out think any guideline provided by the manufacturers. This is what I basically do with the comp rings 180 apart and the oil ring rails 180 apart. I agree they will move around when the eng runs as you see them all over when you take them apart. Ron
