Trunk Divider Material #2561042
10/08/18 07:37 PM
10/08/18 07:37 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Looking for a bulk piece of the material that’s used for the trunk divider. Anyone have a source?
Abe Lincoln
Re: Trunk Divider Material [Re: dart4forte] #2561108
10/08/18 10:09 PM
10/08/18 10:09 PM
Maryland
MoparMike1974 Offline
Maryland
Craft stores like Michaels might have something. Depends on how big of a piece you need. Their stuff is usually only around 3'.
Re: Trunk Divider Material [Re: dart4forte] #2562289
10/11/18 02:50 AM
10/11/18 02:50 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
The original is compressed, un-corrugated cardboard, 1/8" thick.
At Home Depot or Lowe's you can find in the finished lumber/molding aisle about 4 non-plywood items 1/8" x 48" x 96", some of which are pre-finished white, some not. You might like one of the non-white items. With a coat of matte black on it, the only way to tell it is non-original is to remove it and examine it closely.
Re: Trunk Divider Material [Re: dart4forte] #2562372
10/11/18 12:01 PM
10/11/18 12:01 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Home Depot and Lowes both have Luan Plywood which comes in 4'x8' sheets and is 3/16" thick. It's used mostly for the back of cabinets and is finished on one side. Hot rodders have been using that stuff for years for door panels and it will work well for a trunk divider. I'll be using it for my '64 Polara when I do the rear seat delete.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Trunk Divider Material [Re: dart4forte] #2562385
10/11/18 12:21 PM
10/11/18 12:21 PM
70duster340 Offline
70duster340  Offline
I've used the same thing for the door panels in my Duster. I just used an old panel as a template, traced around it, cut it with the desired holes for the window crank, arm rest, and door latch, and covered it with black vinyl with a thin layer of batting. Look good to me, and was much cheaper than purchasing new panels.
Re: Trunk Divider Material [Re: dart4forte] #2562490
10/11/18 04:28 PM
10/11/18 04:28 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Speaking of the trunk divider. Does anyone have firsthand experience with improvements to the trunk divider for noise reduction or would this make much difference?
Re: Trunk Divider Material [Re: dart4forte] #2562802
10/12/18 10:49 AM
10/12/18 10:49 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Make the divider out of aluminum sheet to be NHRA compliant if your racing the car at the track and have the battery in the trunk.
Re: Trunk Divider Material [Re: cruzin] #2562852
10/12/18 12:33 PM
10/12/18 12:33 PM
moparx Offline
moparx  Offline
my one buddy used a dynamat type of stuff on his car, including the trunk divider and surrounding area. the car is very quiet, but that may be due to the entire job, not just the trunk divider. if you are replacing the divider, it wouldn't hurt to use something, even if it's the cheap bubble/foil stuff from the home improvement store. just my idea, your results may vary.
beer
Re: Trunk Divider Material [Re: dart4forte] #2562856
10/12/18 12:47 PM
10/12/18 12:47 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Originals in mine are a black pressboard. Similar to non coregated cardboard.
DMT sells them.
Might be willing to sell you the material or give you the details of what it is.
Re: Trunk Divider Material [Re: dart4forte] #2562864
10/12/18 01:00 PM
10/12/18 01:00 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I assume it is a coupe?
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
