Trunk Divider Material
#2561042
10/08/18 07:37 PM
10/08/18 07:37 PM
Posts: 16,131 Mesa, Arizona
dart4forte
Mesa, Arizona
Looking for a bulk piece of the material that’s used for the trunk divider. Anyone have a source?
Abe Lincoln
Re: Trunk Divider Material
[Re: dart4forte]
#2562289
10/11/18 02:50 AM
10/11/18 02:50 AM
Posts: 1,653 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
The original is compressed, un-corrugated cardboard, 1/8" thick.
At Home Depot or Lowe's you can find in the finished lumber/molding aisle about 4 non-plywood items 1/8" x 48" x 96", some of which are pre-finished white, some not. You might like one of the non-white items. With a coat of matte black on it, the only way to tell it is non-original is to remove it and examine it closely.
[Re: dart4forte]
#2562372
10/11/18 12:01 PM
10/11/18 12:01 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
Home Depot and Lowes both have Luan Plywood which comes in 4'x8' sheets and is 3/16" thick. It's used mostly for the back of cabinets and is finished on one side. Hot rodders have been using that stuff for years for door panels and it will work well for a trunk divider. I'll be using it for my '64 Polara when I do the rear seat delete.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
