Need bushing help for aftermarket temp gauge... #2557403
10/02/18 02:49 AM
10/02/18 02:49 AM
USA
K
ksat Offline OP
ksat  Offline OP
K
USA
I have a Sunpro mechanical temp gauge. I'm trying to figure out what kind of bushing (or adapter) I need in order to install into my 383? Here's a pic of the NPT bushing I bought today. Realized when I got home that it's not what I need. The probe doesn't pass through it, but even if it did how would the probe seal tight? Just confused, so can someone point me the way to what I need to get?
Re: Need bushing help for aftermarket temp gauge... [Re: ksat] #2557406
10/02/18 02:53 AM
10/02/18 02:53 AM
O'reillys has a plastic blister pack with (3) adapters (iirc) & one of em is what you need. It may be online on their site. EDIT the reducer bushing you have is likely 3/8 to 1/4 NPT & the gauge fitting is straight threads & needs the special seat for the "probe" to set down into & is NPT threads on the OD to screw into the intake port. With more thought yes I got the (3) pack at O'reillys & I dont have the part # handy.
Re: Need bushing help for aftermarket temp gauge... [Re: ksat] #2557627
10/02/18 01:17 PM
10/02/18 01:17 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Summit sells them. One side is npt, the sender side is straight thread.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Need bushing help for aftermarket temp gauge... [Re: ksat] #2557644
10/02/18 01:46 PM
10/02/18 01:46 PM
AndyF Online content
AndyF  Online Content
You need a gauge adapter not a NPT bushing. Your local auto parts store should have a gauge adapter but if not you can find them on-line from most anywhere. Go to the Autometer website and search for them then take the part number and search for it. Probably find it at Summit, Jegs, Amazon, ebay, etc. Very common part. If you lived next door to me you could walk over and grab one out of my parts drawer. I probably have 3 or 4 used ones sitting in there.
Re: Need bushing help for aftermarket temp gauge... [Re: ksat] #2557703
10/02/18 03:09 PM
10/02/18 03:09 PM
The adapter you need goes into one of the upper holes, closet to the thermostat housing, nextto the heater hose outlet on the passenger side of the water pump that may be plug now scope
Re: Need bushing help for aftermarket temp gauge... [Re: ksat] #2557732
10/02/18 04:08 PM
10/02/18 04:08 PM
STL
cdstl Offline
cdstl  Offline
STL
You need a set of these. Get the set with the 9851 part number. I ordered a set of Stewart Warner gauges and had to get the adapters without knowing it. Until I began the install. My son's cheapo set from NAPA came with all 3 adapters but not the SW ones.
You'll only need one adapter, and no, there are none available at plumbing stores.
https://www.summitracing.com/int/search/...ture%20Adapters
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Need bushing help for aftermarket temp gauge... [Re: cdstl] #2557758
10/02/18 04:52 PM
10/02/18 04:52 PM
USA
K
ksat Offline OP
ksat  Offline OP
K
USA
Ok I'll check parts store first.
Would the NAPA product have worked? Or did you need specifically a SW?
Re: Need bushing help for aftermarket temp gauge... [Re: ksat] #2557762
10/02/18 04:53 PM
10/02/18 04:53 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree with Andy.I got ours at Advane Auto.There is a step inside that seals the sender tube.Rocky
Chrysler Firepower
Re: Need bushing help for aftermarket temp gauge... [Re: ksat] #2557792
10/02/18 05:18 PM
10/02/18 05:18 PM
STL
cdstl Offline
cdstl  Offline
STL
I actually got his gauges from Auto Zone. Any of the adapters that you can find, like the ones I listed above, will work. Buying a selection like that ensures that you'll get the right one.
