Re: Need bushing help for aftermarket temp gauge...
[Re: ksat]
#2557406
10/02/18 02:53 AM
10/02/18 02:53 AM
RapidRobert
O'reillys has a plastic blister pack with (3) adapters (iirc) & one of em is what you need. It may be online on their site. EDIT the reducer bushing you have is likely 3/8 to 1/4 NPT & the gauge fitting is straight threads & needs the special seat for the "probe" to set down into & is NPT threads on the OD to screw into the intake port. With more thought yes I got the (3) pack at O'reillys & I dont have the part # handy.
[Re: ksat]
#2557732
10/02/18 04:08 PM
10/02/18 04:08 PM
Posts: 1,487 STL
cdstl
STL
You need a set of these. Get the set with the 9851 part number. I ordered a set of Stewart Warner gauges and had to get the adapters without knowing it. Until I began the install. My son's cheapo set from NAPA came with all 3 adapters but not the SW ones. You'll only need one adapter, and no, there are none available at plumbing stores. https://www.summitracing.com/int/search/...ture%20Adapters
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
[Re: cdstl]
#2557758
10/02/18 04:52 PM
10/02/18 04:52 PM
Posts: 87 USA
ksat
USA
Ok I'll check parts store first. My son's cheapo set from NAPA came with all 3 adapters but not the SW ones. Would the NAPA product have worked? Or did you need specifically a SW?
[Re: ksat]
#2557762
10/02/18 04:53 PM
10/02/18 04:53 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
I agree with Andy.I got ours at Advane Auto.There is a step inside that seals the sender tube.Rocky
Chrysler Firepower
[Re: ksat]
#2557792
10/02/18 05:18 PM
10/02/18 05:18 PM
Posts: 1,487 STL
cdstl
STL
Ok I'll check parts store first. My son's cheapo set from NAPA came with all 3 adapters but not the SW ones. Would the NAPA product have worked? Or did you need specifically a SW? I actually got his gauges from Auto Zone. Any of the adapters that you can find, like the ones I listed above, will work. Buying a selection like that ensures that you'll get the right one.
