73 d200 extended cab, 2 piece driveshaft service? #2556879
10/01/18 02:41 AM
10/01/18 02:41 AM
Rancho Cordova, CA
Exit1965 Offline OP
Exit1965  Offline OP
Rancho Cordova, CA
Hi all, I recently got a 73 d200 with extended cab. I'm fairly new to trucks.
It makes a clanking sound when dropped in gear, which sounds to me like a U joint. I crawled underneath expecting to see a regular driveshaft, but this one has a front then a center carrier then another in the back.
Can you all tell me what's involved if I want to service/refresh the entire thing -- from trans to the rear end? How many U joints are in there?
Do people ever convert to a single long driveshaft and do away with the center carrier? I'm sure there's a good reason they made 2 piece, I just don't know what it is.
Thanks from a truck newbie.
Re: 73 d200 extended cab, 2 piece driveshaft service? [Re: Exit1965] #2556945
10/01/18 11:41 AM
10/01/18 11:41 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Should be 3 joints. The carrier bearing is pressed on. Might just pull it and take it to a driveshaft shop is you don't have a press.
I wouldn't replace it with a single shaft. Would change the pinion angle relationship.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 73 d200 extended cab, 2 piece driveshaft service? [Re: Exit1965] #2557007
10/01/18 01:38 PM
10/01/18 01:38 PM
Guitar Jones Offline
You should be able to see and count the joints for yourself. As for a one piece shaft? You can only make them so long.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 73 d200 extended cab, 2 piece driveshaft service? [Re: Exit1965] #2557054
10/01/18 02:51 PM
10/01/18 02:51 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Plus the 2 piece driveshaft keeps more of the driveshaft tucked up for better clearance.
Re: 73 d200 extended cab, 2 piece driveshaft service? [Re: Guitar Jones] #2557195
10/01/18 07:26 PM
10/01/18 07:26 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
What??? do his own research...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 73 d200 extended cab, 2 piece driveshaft service? [Re: Exit1965] #2559336
10/05/18 11:53 AM
10/05/18 11:53 AM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
In addition to the reasons already mentioned, if the truck is an automatic it is a short tail trans and does not have a slip yoke at the back of the trans. Instead the u joint attaches to a yoke bolted on the end of the trans output shaft.
If switched to one piece, this would leave no room for the driveshaft to move with the rear end when the suspension moves going up and down when driving. It would require you changing trans to the car type long tail shaft and slip yoke to use one piece.
FYI, make damn sure you mark the phasing of how the two pieces of the drive shaft now are in relation to one another before taking it apart. Put it back together the same way it came out, or you might have one hell of a vibration.
