Re: 73 d200 extended cab, 2 piece driveshaft service?
[Re: Exit1965]
#2556945
10/01/18 11:41 AM
10/01/18 11:41 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Should be 3 joints. The carrier bearing is pressed on. Might just pull it and take it to a driveshaft shop is you don't have a press. I wouldn't replace it with a single shaft. Would change the pinion angle relationship.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: Exit1965]
#2557007
10/01/18 01:38 PM
10/01/18 01:38 PM
Posts: 20,625 in a cattle trailer down by th...
Guitar Jones
You should be able to see and count the joints for yourself. As for a one piece shaft? You can only make them so long.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2557195
10/01/18 07:26 PM
10/01/18 07:26 PM
Posts: 2,103 Byron, NY
W.I.N. Racing
Byron, NY
You should be able to see and count the joints for yourself. As for a one piece shaft? You can only make them so long. What??? do his own research...
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Exit1965]
#2559336
10/05/18 11:53 AM
10/05/18 11:53 AM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
In addition to the reasons already mentioned, if the truck is an automatic it is a short tail trans and does not have a slip yoke at the back of the trans. Instead the u joint attaches to a yoke bolted on the end of the trans output shaft. If switched to one piece, this would leave no room for the driveshaft to move with the rear end when the suspension moves going up and down when driving. It would require you changing trans to the car type long tail shaft and slip yoke to use one piece.
FYI, make damn sure you mark the phasing of how the two pieces of the drive shaft now are in relation to one another before taking it apart. Put it back together the same way it came out, or you might have one hell of a vibration.
