Found a set of new old stock lifters. Any good?
#2555524
09/27/18 01:32 PM
09/27/18 01:32 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
While digging through the top of the tool box yesterday, looking for a zip tie, I came across a full set of hydraulic lifters I had purchased for a project about 12 to 15 years ago.
Would these still be good? They haven't ever been out of the boxes, but they haven't been stored in temp or humidity controlled location.
They are completely taped up, so I didn't want to break the seal since I don't have a time frame in which I will need them. But if they may still be viable I will add them to the parts shelf with the cam bearings they were purchased with.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: Found a set of new old stock lifters. Any good?
[Re: hp383]
#2555603
09/27/18 04:57 PM
09/27/18 04:57 PM
hp383
State of Confusion
Its SW Iowa. It can be terribly humid, or pretty arid depending on the season and the weather gods.
I guess I will break the seals and see whats inside.
Then if they are OK, I will try to seal them in a zip lock with a couple desiccant packets or something.
[Re: hp383]
#2555618
09/27/18 05:33 PM
09/27/18 05:33 PM
RapidRobert
They're junk, sell them to me! Back then quality was good.
[Re: BSB67]
#2555806
09/28/18 01:38 AM
09/28/18 01:38 AM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I've had these for 30 yrs !! Probably a lot better than any Mopar hydraulic lifter available today. Yup.
