Found a set of new old stock lifters. Any good? #2555524
09/27/18 01:32 PM
09/27/18 01:32 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
While digging through the top of the tool box yesterday, looking for a zip tie, I came across a full set of hydraulic lifters I had purchased for a project about 12 to 15 years ago.
Would these still be good? They haven't ever been out of the boxes, but they haven't been stored in temp or humidity controlled location.
They are completely taped up, so I didn't want to break the seal since I don't have a time frame in which I will need them. But if they may still be viable I will add them to the parts shelf with the cam bearings they were purchased with.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Found a set of new old stock lifters. Any good? [Re: hp383] #2555530
09/27/18 01:46 PM
09/27/18 01:46 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The only bad thing is rust, is it damp or dry where they were stored? Sometimes they have a desiccant wrapping paper around them.
They might have oil on them, and that oil could have turned to a crust. Then they would need to come apart and be cleaned out.
Re: Found a set of new old stock lifters. Any good? [Re: hp383] #2555603
09/27/18 04:57 PM
09/27/18 04:57 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Its SW Iowa. It can be terribly humid, or pretty arid depending on the season and the weather gods.
I guess I will break the seals and see whats inside.
Then if they are OK, I will try to seal them in a zip lock with a couple desiccant packets or something.
Re: Found a set of new old stock lifters. Any good? [Re: hp383] #2555613
09/27/18 05:28 PM
09/27/18 05:28 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
They were usually wrapped in brown waxy paper from the factory. If not rusted I'd pump a little oil in them, work the plungers by hand and run them.
Re: Found a set of new old stock lifters. Any good? [Re: hp383] #2555618
09/27/18 05:33 PM
09/27/18 05:33 PM
They're junk, sell them to me! Back then quality was good.
Re: Found a set of new old stock lifters. Any good? [Re: hp383] #2555656
09/27/18 07:31 PM
09/27/18 07:31 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
actually, 12-15yrs ago may put you in the worst time for hydraulic tappets. a lot of tappet problems in that time frame. I had two bad sets in 2003 and i'm not sure of the date when johnsons were starting to be manufactured again but it was a while past 2003.
Re: Found a set of new old stock lifters. Any good? [Re: lewtot184] #2555661
09/27/18 07:53 PM
09/27/18 07:53 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I've had these for 30 yrs !! realcrazy
Re: Found a set of new old stock lifters. Any good? [Re: 62maxwgn] #2555675
09/27/18 08:30 PM
09/27/18 08:30 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Probably a lot better than any Mopar hydraulic lifter available today.
Re: Found a set of new old stock lifters. Any good? [Re: BSB67] #2555806
09/28/18 01:38 AM
09/28/18 01:38 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Yup.
Re: Found a set of new old stock lifters. Any good? [Re: hp383] #2555833
09/28/18 03:40 AM
09/28/18 03:40 AM
Maryland
MoparMike1974 Offline
Maryland
I have a new 528 solid mopar cam I bought about 15 years ago. Opened the box the other day and the cam looks clean and lifters look like new.
If you pull them out be sure not to handle them without some latex gloves on. Normally it wouldnt be an issue but if your putting them back in storage the acids from you skin will make them rust.
Re: Found a set of new old stock lifters. Any good? [Re: hp383] #2555856
09/28/18 08:15 AM
09/28/18 08:15 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
what I've noticed about Stanadynes is the foot of the tappet isn't as nicely machined as the Eatons or Johnsons. the real problem is the internals with hydraulic tappets. i'm running a flat tappet solid i'm pretty sure has Stanadyne tappets without issue for close to 20,000 miles. but, the Stanadyne hydraulics are an issue. I talked to Mark Engle about this around 2003 when all the tappet problems were raging and he told me Stanadyne was the least desirable with Eatons his favorite.
