Shocks #2554191
09/24/18 07:30 PM
09/24/18 07:30 PM
Joplin, Missouri
Mac's Hemi 64 Offline OP
Joplin, Missouri
Looking for some recommendations for new shocks. 1964 Dodge, 4000 pounds with me in it. Running SS springs, snubber, drag radials,automatic with 488 gears. Car is bouncing and killing 60 foot times. Any help is appreciated. Thanks, Mark
Re: Shocks [Re: Mac's Hemi 64] #2554216
09/24/18 08:31 PM
09/24/18 08:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Might want to look at Viking shocks but maybe with stronger
valving and double adjustables
wave
Re: Shocks [Re: Mac's Hemi 64] #2554217
09/24/18 08:34 PM
09/24/18 08:34 PM
AndyF Offline
AndyF  Offline
What shocks do you have in it now? You'll also probably get a lot of recommendations to switch over to Caltrac springs with the bar but even with SS springs you should be able to tame it down. How big is the budget? You can get Calvert adjustable springs for $100 each, double adjustable shocks cost a lot more.
I started making my own lower shock plates so I could get the shock in the correct position. Getting the correct travel on the shock was important for my application.
Re: Shocks [Re: AndyF] #2554235
09/24/18 09:08 PM
09/24/18 09:08 PM
southeast ky
mills.mopar Offline
mills.mopar  Offline
southeast ky
How fast is your car? What are the 60` times?
Jeff
If you love it lube it
68 dart
37 dodge coupe
71 challenger
Re: Shocks [Re: mills.mopar] #2554267
09/24/18 10:40 PM
09/24/18 10:40 PM
Joplin, Missouri
Joplin, Missouri
I am running 1.90's right now. It is mostly a street car. Best time is 11.20 @ 120 spinning the tires. It is totally built as the 64's were. Trying to make it work without going with upgraded suspension.
Re: Shocks [Re: Mac's Hemi 64] #2554271
09/24/18 10:45 PM
09/24/18 10:45 PM
AndyF Offline
AndyF  Offline
For a street car I'd go with Koni shocks. Koni shocks are adjustable and are very high quality. They have a 5/8 lower bushing which is the wrong size for a Mopar so you have to work around that. I made lower shock plates for my Coronet. I run SS springs on the Coronet and it is a street car. The car launches pretty nice as long as I can keep it hooked rather than up in smoke.
Another thing you might do is play with clamps on the springs. You might want to add some clamps on the front of the spring to stiffen them up.
Re: Shocks [Re: AndyF] #2554272
09/24/18 10:52 PM
09/24/18 10:52 PM
Joplin, Missouri
Joplin, Missouri
Thanks Andy, The springs are clamped. Car is lifting the rear and planting the tires hard now on the hit. Video looks like, and feels like it is bouncing. It just has cheap 90/10's on it now.
Re: Shocks [Re: Mac's Hemi 64] #2554288
09/24/18 11:44 PM
09/24/18 11:44 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I have just put Viking double adjustable's on my 71 Barra , big improvement.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Shocks [Re: AndyF] #2554295
09/25/18 12:08 AM
09/25/18 12:08 AM
Washington
madscientist Offline
Washington
How do you adjust that shock and is it double adjustable.
Re: Shocks [Re: Mac's Hemi 64] #2554399
09/25/18 11:18 AM
09/25/18 11:18 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Viking but expensive. I run qa1 single adjustable R series on the front stiffer compression the knob really adjustes the rebound. I would put a double adjustable in the rear. Viking or qa1
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Shocks [Re: Mac's Hemi 64] #2554406
09/25/18 11:28 AM
09/25/18 11:28 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have some double adjustable vikings on my car, good value. They work well and the price wasn't crazy
68 Barracuda Formula S 340
Re: Shocks [Re: Mac's Hemi 64] #2554767
09/25/18 10:30 PM
09/25/18 10:30 PM
Joplin, Missouri
Joplin, Missouri
Andy. What it the combo on your Coronet? Any times? Educate me on changing the angle of the shock. Thanks
Re: Shocks [Re: Mac's Hemi 64] #2555262
09/26/18 10:47 PM
09/26/18 10:47 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
I haven't run a SS spring since the late 80's. I thought that with a 400 HP sb in an street equipped A body, I thought I could get away with SS springs and longer rear shocks, the way that I did years ago. Is that theory ancient history?
Re: Shocks [Re: A/MP] #2555376
09/27/18 02:55 AM
09/27/18 02:55 AM
Washington
Washington
Yes. You have three choices of simple traction bars in the Cal Tracs, Slid-A-links or the Asassin bars.
I can't think of a single reason to use SS springs and/or a pinion snubber. Ever.
Re: Shocks [Re: Mac's Hemi 64] #2555395
09/27/18 04:43 AM
09/27/18 04:43 AM
What does the rear spring shackle angle look like at static height unloaded? Is it almost straight up and down or angle backwards some?
Re: Shocks [Re: Cab_Burge] #2555407
09/27/18 08:12 AM
09/27/18 08:12 AM
Joplin, Missouri
Joplin, Missouri
Cab, rear shackle is straight up and down. I know there are way better ways to go than just the SS springs. This is just fun to keep it all old school. I am also wondering if too short of shock on the front might be making the chassis unload? Thanks for the help.
Re: Shocks [Re: Mac's Hemi 64] #2555425
09/27/18 10:05 AM
09/27/18 10:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If your front shocks are too short it will
have a tendency to unload the rear.. you would
like about 5" of travel on the fronts
wave
Re: Shocks [Re: Mac's Hemi 64] #2555477
09/27/18 11:46 AM
09/27/18 11:46 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Oh something I found check for clearance between the body of the shock and the frame mounted bump stop pad. My qa1’s hit the side of the shock body. Same thing happened on a b body In my class. It happens a full droop. A lttle clearance grind on the bracket and you are fine.
Re: Shocks [Re: Mac's Hemi 64] #2555491
09/27/18 12:04 PM
09/27/18 12:04 PM
fullmetaljacket Offline
Do what you have to to make that shackle angle veer towards the rear of the car. Straight up and down is not recommended because it does not allow the spring suspension to work correctly (not raising/separating the body and planting the rear end) thus unloading the rear tires.
I also love to try and keep it stock. Some cars both on and off this site have achieved some good short times using leaf springs (SS or not)
I run the Trip-city springs on mine. Just a stiffer and thicker spring leaf/s compared to the current TOY springs they now call SS springs.
Re: Shocks [Re: Mac's Hemi 64] #2555547
09/27/18 02:20 PM
09/27/18 02:20 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
We've achieved low 1.5x 60 foot at 123mph with Rancho adjustables. They need to be set tight. Try about 15psi. I would think at 120mph you should be able to go low,1.60 high 1.50s. Make sure the shackle doesn't limit travel. You may need to be moved forward or made longer. Better yet switch to sliders. Make sure the shock is long enough so it doesn't limit travel. If it does add an extention to the mount. Shock angle at this stage of the game isn't really a factor. Go to you tube; "64 Dodge shock tuning"
https://www.youtube.com/watch?v=sjZDXBXRC9Q
Doug
