Re: Shocks
[Re: AndyF]
#2554235
09/24/18 09:08 PM
09/24/18 09:08 PM
Posts: 252 southeast ky
mills.mopar
southeast ky
How fast is your car? What are the 60` times?
Jeff
If you love it lube it
68 dart 37 dodge coupe 71 challenger
Re: Shocks
[Re: AndyF]
#2554272
09/24/18 10:52 PM
09/24/18 10:52 PM
Posts: 154 Joplin, Missouri
Mac's Hemi 64
Joplin, Missouri
Thanks Andy, The springs are clamped. Car is lifting the rear and planting the tires hard now on the hit. Video looks like, and feels like it is bouncing. It just has cheap 90/10's on it now.
Re: Shocks
[Re: Mac's Hemi 64]
#2554288
09/24/18 11:44 PM
09/24/18 11:44 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have just put Viking double adjustable's on my 71 Barra , big improvement.
1963 Plymouth Max Wedge 1971 Barracuda
Re: Shocks
[Re: AndyF]
#2554295
09/25/18 12:08 AM
09/25/18 12:08 AM
Posts: 4,457 Washington
madscientist
Washington
For a street car I'd go with Koni shocks. Koni shocks are adjustable and are very high quality. They have a 5/8 lower bushing which is the wrong size for a Mopar so you have to work around that. I made lower shock plates for my Coronet. I run SS springs on the Coronet and it is a street car. The car launches pretty nice as long as I can keep it hooked rather than up in smoke.
Another thing you might do is play with clamps on the springs. You might want to add some clamps on the front of the spring to stiffen them up. How do you adjust that shock and is it double adjustable.
Re: Shocks
[Re: Mac's Hemi 64]
#2554406
09/25/18 11:28 AM
09/25/18 11:28 AM
Posts: 8,032 Tulsa OK
Bad340fish
Tulsa OK
I have some double adjustable vikings on my car, good value. They work well and the price wasn't crazy
68 Barracuda Formula S 340
Re: Shocks
[Re: A/MP]
#2555376
09/27/18 02:55 AM
09/27/18 02:55 AM
madscientist
Washington
I haven't run a SS spring since the late 80's. I thought that with a 400 HP sb in an street equipped A body, I thought I could get away with SS springs and longer rear shocks, the way that I did years ago. Is that theory ancient history? Yes. You have three choices of simple traction bars in the Cal Tracs, Slid-A-links or the Asassin bars. I can't think of a single reason to use SS springs and/or a pinion snubber. Ever.
Re: Shocks
[Re: Mac's Hemi 64]
#2555395
09/27/18 04:43 AM
09/27/18 04:43 AM
Posts: 43,269 Bend,OR USA
Cab_Burge
What does the rear spring shackle angle look like at static height unloaded? Is it almost straight up and down or angle backwards some?
Re: Shocks
[Re: Mac's Hemi 64]
#2555425
09/27/18 10:05 AM
09/27/18 10:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If your front shocks are too short it will have a tendency to unload the rear.. you would like about 5" of travel on the fronts
Re: Shocks
[Re: Mac's Hemi 64]
#2555547
09/27/18 02:20 PM
09/27/18 02:20 PM
Posts: 9,865 MI, usa
dvw
MI, usa
We've achieved low 1.5x 60 foot at 123mph with Rancho adjustables. They need to be set tight. Try about 15psi. I would think at 120mph you should be able to go low,1.60 high 1.50s. Make sure the shackle doesn't limit travel. You may need to be moved forward or made longer. Better yet switch to sliders. Make sure the shock is long enough so it doesn't limit travel. If it does add an extention to the mount. Shock angle at this stage of the game isn't really a factor. Go to you tube; "64 Dodge shock tuning" https://www.youtube.com/watch?v=sjZDXBXRC9QDoug
