Single feed vs. dual feed carb. #2551764
09/19/18 12:41 AM
09/19/18 12:41 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I'm looking at getting a new Holley carb. that comes in both single and dual feed versions. Other than the obvious extra feed on the dual feed, are there any other differences between the two? Does the extra feed provide a better supply or flow of fuel? Just trying to decide if I should choose one version over the other. The carb. will be used on a mild 440.
Re: Single feed vs. dual feed carb. [Re: 440mopar] #2551790
09/19/18 02:13 AM
09/19/18 02:13 AM
Washington
madscientist Offline
Washington
Other than room or OE packaging I can't see why you wouldn't want a dual feed set up. One line for each needle and seat...I don't see a bad thing.
Re: Single feed vs. dual feed carb. [Re: 440mopar] #2551819
09/19/18 07:18 AM
09/19/18 07:18 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've used both types of carbs over the years, no big benefits or draw backs, esp since your application is a mild street 440, full race application is another story...
Re: Single feed vs. dual feed carb. [Re: 440mopar] #2551841
09/19/18 09:33 AM
09/19/18 09:33 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
understanding why holley went to a "center pivot" needle and seat vs the tradional "side pivot" may help in selection.
Re: Single feed vs. dual feed carb. [Re: 440mopar] #2551842
09/19/18 09:45 AM
09/19/18 09:45 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Both carbs have 2 needle and seats.
The single feed has a transfer tube and has side hung floats
The dual feed has 2 fuel lines and center hung floats. It flows more fuel than the single feed.
A single feed will work fine on a mild 440 for the street.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Single feed vs. dual feed carb. [Re: 440mopar] #2551882
09/19/18 11:51 AM
09/19/18 11:51 AM
IL
furious70 Offline
furious70  Offline
IL
maybe silly, but to me a dual feed has the 'hot rod look' and the single feeds are pedestrian looking.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Single feed vs. dual feed carb. [Re: 440mopar] #2551952
09/19/18 02:55 PM
09/19/18 02:55 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
68 426 Dart-Barracuda, single feed square bowls and vacuum secondary's.
#3310, single line, would be my choice.
Re: Single feed vs. dual feed carb. [Re: cudaman1969] #2551994
09/19/18 05:14 PM
09/19/18 05:14 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
FWIW With a stock height intake sometimes a dual feed line runs right into the distributor depending on which dual feed line you use... twocents
...FAFO...
Re: Single feed vs. dual feed carb. [Re: skicker] #2551997
09/19/18 05:23 PM
09/19/18 05:23 PM
moparmarks Offline
moparmarks  Offline
Some also hit the manifold.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Single feed vs. dual feed carb. [Re: 440mopar] #2552034
09/19/18 07:11 PM
09/19/18 07:11 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the past month I've been playing with a 750 edelbrock on a near stock 440. surprisingly impressed with it.
