Re: Single feed vs. dual feed carb.
[Re: 440mopar]
#2551790
09/19/18 02:13 AM
09/19/18 02:13 AM
Posts: 4,457 Washington
madscientist
Washington
Other than room or OE packaging I can't see why you wouldn't want a dual feed set up. One line for each needle and seat...I don't see a bad thing.
[Re: 440mopar]
#2551819
09/19/18 07:18 AM
09/19/18 07:18 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I'm looking at getting a new Holley carb. that comes in both single and dual feed versions. Other than the obvious extra feed on the dual feed, are there any other differences between the two? Does the extra feed provide a better supply or flow of fuel? Just trying to decide if I should choose one version over the other. The carb. will be used on a mild 440. I've used both types of carbs over the years, no big benefits or draw backs, esp since your application is a mild street 440, full race application is another story...
[Re: 440mopar]
#2551842
09/19/18 09:45 AM
09/19/18 09:45 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Both carbs have 2 needle and seats. The single feed has a transfer tube and has side hung floats The dual feed has 2 fuel lines and center hung floats. It flows more fuel than the single feed. A single feed will work fine on a mild 440 for the street.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: 440mopar]
#2551882
09/19/18 11:51 AM
09/19/18 11:51 AM
Posts: 2,255 IL
furious70
IL
maybe silly, but to me a dual feed has the 'hot rod look' and the single feeds are pedestrian looking.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: 440mopar]
#2551952
09/19/18 02:55 PM
09/19/18 02:55 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
68 426 Dart-Barracuda, single feed square bowls and vacuum secondary's. #3310, single line, would be my choice.
[Re: skicker]
#2551997
09/19/18 05:23 PM
09/19/18 05:23 PM
moparmarks
FWIW With a stock height intake sometimes a dual feed line runs right into the distributor depending on which dual feed line you use... Some also hit the manifold.
