1968 A-Body Engine and Transmission VIN's #2548913
09/11/18 06:23 PM
09/11/18 06:23 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
I just look at a nicely restorded H code 68 Dart GTS 383 4-speed for a friend.
When checking for the VIN of the back of the block near the oil sending unit. I noticed that the numbers looked a owner stamping and not factory.
Then I realized that who ever did the stamping used the SO number from the fender tag and not the VIN from the dash.
After we put the car up on a lift, I found that the transmission pad on the passenger side that the six sequence numbers from the VIN stamped up side down on the pad.
In 1968 did the factory stamp the VIN on the pad of the 4 speed cars?
Re: 1968 A-Body Engine and Transmission VIN's [Re: rarefish] #2548921
09/11/18 06:33 PM
09/11/18 06:33 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
VIN should have been stamped in both spots.
Odd situation, do you have photos of both stamps?
If the block was re-stamped, that says enough about the owner for any buyer to look elsewhere.
Re: 1968 A-Body Engine and Transmission VIN's [Re: Alaskan_TA] #2549017
09/11/18 10:42 PM
09/11/18 10:42 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
What is the build date on the fender tag?
JB Rhinehart, Realist
A-Body's RULE!
Re: 1968 A-Body Engine and Transmission VIN's [Re: rarefish] #2549027
09/11/18 11:03 PM
09/11/18 11:03 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
The friend has a few pics of the stamping. I will see if I can get them sent to me so I can post them here.
Re: 1968 A-Body Engine and Transmission VIN's [Re: Rhinodart] #2549031
09/11/18 11:10 PM
09/11/18 11:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Fender tags did not record an actual 'build date' - unless it was pure coincidence.
Re: 1968 A-Body Engine and Transmission VIN's [Re: rarefish] #2549033
09/11/18 11:11 PM
09/11/18 11:11 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Here are some pics of the block stamping, trans pad.
The SPD is 418
Re: 1968 A-Body Engine and Transmission VIN's [Re: rarefish] #2549035
09/11/18 11:14 PM
09/11/18 11:14 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Here is the fender tag.
Re: 1968 A-Body Engine and Transmission VIN's [Re: Alaskan_TA] #2549064
09/12/18 12:15 AM
09/12/18 12:15 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No shiite Sherlock, just want an approximation, we all know this by now... eyes Just trying to find out if it was an early or late build.
A-Body's RULE!
Re: 1968 A-Body Engine and Transmission VIN's [Re: rarefish] #2549069
09/12/18 12:30 AM
09/12/18 12:30 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Ask the real question then?
No need to be rude or imply profanity.
Re: 1968 A-Body Engine and Transmission VIN's [Re: rarefish] #2549072
09/12/18 12:34 AM
09/12/18 12:34 AM
cheshire, ct
davesmopars Offline
davesmopars  Offline
cheshire, ct
the trans looks like a factory stamping
Keeper of the 440 M code Cuda registry
mcodecuda@yahoo.com
Re: 1968 A-Body Engine and Transmission VIN's [Re: davesmopars] #2549077
09/12/18 12:54 AM
09/12/18 12:54 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
iagree what is stamped on the pad below the distributor scope
Re: 1968 A-Body Engine and Transmission VIN's [Re: 6bblgt] #2549142
09/12/18 10:50 AM
09/12/18 10:50 AM
New York
rarefish Offline OP
rarefish  Offline OP
New York
That I did not get a look at, unfortunately. When on the lift I noticed that it had a 187 C-body oil pan and the casting date on the block was in Aug. 1967
Re: 1968 A-Body Engine and Transmission VIN's [Re: rarefish] #2549176
09/12/18 12:35 PM
09/12/18 12:35 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Used to be a $600 hit if missing the oil pan, now that Vans Auto has reproduced them for $200 plus pick-up it is easier to swallow if you don't mind using reproduction parts. up
A-Body's RULE!
Re: 1968 A-Body Engine and Transmission VIN's [Re: rarefish] #2549568
09/13/18 12:33 PM
09/13/18 12:33 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Taking a close look that the trans pad. I see that the assembly date is 2461 which is 4-23-68. The vehicle's SPD is 4-18-68
Does this maybe make you question if is the original transmission?
Re: 1968 A-Body Engine and Transmission VIN's [Re: rarefish] #2549593
09/13/18 01:27 PM
09/13/18 01:27 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That probably just proves Barry's point that the SPD is just a suggestion. work
A-Body's RULE!
Re: 1968 A-Body Engine and Transmission VIN's [Re: Rhinodart] #2549651
09/13/18 03:33 PM
09/13/18 03:33 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Yes. If that is the original transmission....
Question about the 1968 BB stripe.
Is it suppose to to be one that goes straight across the trunk lid or does it come to a point in the middle of the lid? Kind of making a slight V if you understand what I talking about.
Re: 1968 A-Body Engine and Transmission VIN's [Re: rarefish] #2551266
09/17/18 09:23 PM
09/17/18 09:23 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yes there is a vee in it. I have seen people put it in upside down before...
A-Body's RULE!
Re: 1968 A-Body Engine and Transmission VIN's [Re: rarefish] #2551300
09/17/18 10:52 PM
09/17/18 10:52 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
There is a red with white interior and tail stripe 1968 Hemi 4 spd Charger out there that was done just like that Dart. It has the original numbers matching 4 speed transmission (VIN sequence which is correct) and an owner stamped block which has the SO number stamped into it which is not correct. As a couple people have already pointed out, the VIN sequence should be on both the engine and trans.
.02
Re: 1968 A-Body Engine and Transmission VIN's [Re: rarefish] #2551305
09/17/18 11:04 PM
09/17/18 11:04 PM
New York
rarefish Offline OP
rarefish  Offline OP
New York
Thanks guys for the info and answers....
