Re: Picture of tailpipe using oil
[Re: Hemi ragtop]
#2547853
09/09/18 11:13 AM
09/09/18 11:13 AM
RapidRobert
I would think that the tailpipes would be black ish from oil and or rich. I'd more suspect a leak (especially the quantity you are loseing) especially if the plugs look decent.
[Re: Hemi ragtop]
#2547861
09/09/18 11:30 AM
09/09/18 11:30 AM
Posts: 2,117 Byron, NY
W.I.N. Racing
Byron, NY
Never mind, this site can not accept a standard picture, what a shame! Does this say something about the lack of tecknology of Moparts? I can post standard pics...maybe its your tec hnology??
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Hemi ragtop]
#2547885
09/09/18 12:21 PM
09/09/18 12:21 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
When you did the oil change, did you check the oil level on the stick after run up? Maybe it's a calibration issue. I feel using that much oil, you would be getting some tell tale blue smoke while driving.
[image][/image]
[Re: Hemi ragtop]
#2547931
09/09/18 02:05 PM
09/09/18 02:05 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
can you give us less information to go on?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Hemi ragtop]
#2548215
09/10/18 01:39 AM
09/10/18 01:39 AM
Posts: 43,259 Bend,OR USA
Cab_Burge
Is this a Hemi motor? The reason I ask is to see if you can pull the plugs and see if the plugs are shiny or dull on the insulator and ground strap If it is hemi motor and you don't have the spark plug seals sealed up it is hard to get them out without drowning them in oil
