Picture of tailpipe using oil #2547742
09/08/18 11:05 PM
09/08/18 11:05 PM
Tennessee
Hemi ragtop Offline OP
Tennessee
Can you see where a quart of oil is going in 120 miles?
Never mind, this site can not accept a standard picture, what a shame! Does this say something about the lack of tecknology of Moparts?
At any rate, the exhaust is WHITE! Is this engine burning that much oil efficiently?
Re: Picture of tailpipe using oil [Re: Hemi ragtop] #2547853
09/09/18 11:13 AM
09/09/18 11:13 AM
I would think that the tailpipes would be black ish from oil and or rich. I'd more suspect a leak (especially the quantity you are loseing) especially if the plugs look decent.
Re: Picture of tailpipe using oil [Re: Hemi ragtop] #2547861
09/09/18 11:30 AM
09/09/18 11:30 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I can post standard pics...maybe its your technology??
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Picture of tailpipe using oil [Re: Hemi ragtop] #2547885
09/09/18 12:21 PM
09/09/18 12:21 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
When you did the oil change, did you check the oil level on the stick after run up? Maybe it's a calibration issue. I feel using that much oil, you would be getting some tell tale blue smoke while driving.
[image][/image]
Re: Picture of tailpipe using oil [Re: Hemi ragtop] #2547931
09/09/18 02:05 PM
09/09/18 02:05 PM
jersey
Spaceman Spiff Offline
jersey
can you give us less information to go on?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Picture of tailpipe using oil [Re: Hemi ragtop] #2548053
09/09/18 07:51 PM
09/09/18 07:51 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
"tecknology"?
My pictures work, my hemis burned slicks and not much oil.
Re: Picture of tailpipe using oil [Re: Hemi ragtop] #2548215
09/10/18 01:39 AM
09/10/18 01:39 AM
Is this a Hemi motor?
The reason I ask is to see if you can pull the plugs and see if the plugs are shiny or dull on the insulator and ground strap work
If it is hemi motor and you don't have the spark plug seals sealed up it is hard to get them out without drowning them in oil whiney
Re: Picture of tailpipe using oil [Re: Hemi ragtop] #2548299
09/10/18 11:19 AM
09/10/18 11:19 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
So, you're saying that the insides of the tailpipes are whitish?
That wouldn't be oil usage, it'd be a very lean condition.
The old-school tailpipe-reading goes like this:
Too rich/unburned fuel = sooty black
Burning oil = damp black
Medium grey-tan = ideal
(Best checked after a run down the highway)
