Which master cylinder should I use? #2544579
09/02/18 12:29 PM
09/02/18 12:29 PM
Easton, PA
68DART360 Offline OP
Easton, PA
I have stock front disc brakes and Wilwood rear drag disc brakes. Should I get the MP 1 1/32 or 1 1/8 bore master cylinder? Other suggestions for a new brake master cylinder?
Re: Which master cylinder should I use? [Re: 68DART360] #2544610
09/02/18 01:26 PM
09/02/18 01:26 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
It depends on the pedal throw and firmness you desire.
A 1 1/8" bore truck master is very firm and a short throw but I prefer that. 15/16 rwd car master is preferred by quite a few people.
O'Reillys sells the aluminum MC's for $26.
'63 Dodge 330
11.19 @ 121 mph
Re: Which master cylinder should I use? [Re: GY3] #2544689
09/02/18 03:29 PM
09/02/18 03:29 PM
Originally Posted By GY3
[quote=68DART360]
iagree Smaller stops better with a lot less pedal effort work
Re: Which master cylinder should I use? [Re: 68DART360] #2544723
09/02/18 05:03 PM
09/02/18 05:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Sometimes you don't have a choice; if the combination of calipers and the pedal ratio require more fluid volume, you'll have to sacrifice line pressure and go with the larger diameter MC or live with a low pedal.
Re: Which master cylinder should I use? [Re: John_Kunkel] #2544734
09/02/18 05:33 PM
09/02/18 05:33 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have the same basic setup on my Savoy and I have used the 1 1/8 bore master from Wagner and then tried the 7/8 bore Strange unit and the pedal feel wasn't that drastic. Both performed well but the Strange unit had a more aggressive stop than the Wagner unit. Both of them felt confident but the Wagner was "smoother" shruggy
I think the Wagner was an 85 Dodge Diplomat application.
I use them without any prop valve just a distribution block and the car stops perfectly from 125 MPH.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Which master cylinder should I use? [Re: 68DART360] #2544770
09/02/18 07:11 PM
09/02/18 07:11 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My 69 Dart has Strange front brakes and Wilwood rears and I tried the 1 1/32" mc and didn't like it at all. The car currently has a 15/16" mc and stops much better. Originally I had bbp disk on the front and Wilwoods on the rear with a 73 proportion valve with a factory small drum mc and it stopped great. I'd really like to try a 7/8" bore mc some time.
Re: Which master cylinder should I use? [Re: GY3] #2544772
09/02/18 07:24 PM
09/02/18 07:24 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
[/quote]
O'Reillys sells the aluminum MC's for $26. [/quote]
Part # ?
Re: Which master cylinder should I use? [Re: Mr340] #2544796
09/02/18 08:46 PM
09/02/18 08:46 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
'63 Dodge 330
11.19 @ 121 mph
Re: Which master cylinder should I use? [Re: 68DART360] #2544805
09/02/18 09:11 PM
09/02/18 09:11 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Wilwood fronts, Strange rears.... even with the drum rears prefered the 15/16 bore. Still might try proportioning a little more to the rear one day. Currently running no prop valve
http://www.doctordiff.com/aluminum-master-cylinder-kit.html
Re: Which master cylinder should I use? [Re: 68DART360] #2544807
09/02/18 09:14 PM
09/02/18 09:14 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Thanks up
Re: Which master cylinder should I use? [Re: 68DART360] #2544894
09/03/18 01:35 AM
09/03/18 01:35 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I had the same set up in my Cuda since 1988 I used the stock master and factory plumbing. The only thing I did was pull the residual valve out of the master cylinder. It was simple process. Inserted a small screw into the brake line(rear brakes) seat cone in the master, wiggled it out and the residual valve popped out. Inserted the seat cone then the line and blead the system. It has a great pedal The car was not super fast ran 10 teens at 130.
Ok
Re: Which master cylinder should I use? [Re: Mr340] #2544998
09/03/18 11:34 AM
09/03/18 11:34 AM
Easton, PA
Easton, PA
I forgot to mention I currently have a master cylinder from a drum front and rear in the car now. I will probably try the 1 1/8 from Napa. Thanks for the link to the part numbers. beer Cudatom, I had recently seen that trick but was planning to replace my master cylinder which is leaking like crazy.
Re: Which master cylinder should I use? [Re: 68DART360] #2545063
09/03/18 01:10 PM
09/03/18 01:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm gonna change out my master on the Rampage..
its a fairly light car but the pedal is just a
little too hard.. is I recall its a 7/8" now
but I think I'll put a 3/4" on it.. it has
Strange struts in front and ford big drums brakes
on the rear.. no prop valve
