Page 3 of 9 1 2 3 4 5 6 7 8 9
Re: Drag Week 2018 [Re: JERICOGTX] #2543696
08/31/18 02:13 AM
08/31/18 02:13 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Cool stuff Jeff!
Re: Drag Week 2018 [Re: JERICOGTX] #2543742
08/31/18 09:19 AM
08/31/18 09:19 AM
MN
JERICOGTX Offline OP
MN
Going to be a fun trip Jay! If all goes well, I'll get to see 4 new Drag Strips, and a few new states I've never been to.
69 GTX 68 Road Runner
Re: Drag Week 2018 [Re: JERICOGTX] #2543911
08/31/18 04:31 PM
08/31/18 04:31 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Yup, after more than 5 years since i Started the project, I finally made it to the track. Thanks to Kevin and Jeff for all the help! I made 3 passes, none of them were full clean runs. There are issues to work out, but nothing really bad. I couldn't get the T56 Magnum to shift clean under power, their is a mystery oil leak to find and fix, and the Nut behind the wheel needs dialing in. But I'm satisfied. Nothing blew up, I didn't crash, and I have a to-do list.
I am going to remove some counterweight from the clutch and see if that helps it shift.
I was trying to use my GoPro as a data logger, filming all the gauges. For some reason, it didn't record the Innovate MTX-l a/f gauges well. It just showed a lot of flashing. Maybe the shutter speed of the camera aligns with the digital gauge in a bad way?
There sure is lot's of work yet to do before drag week, I need to get busy.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag Week 2018 [Re: JERICOGTX] #2543969
08/31/18 07:41 PM
08/31/18 07:41 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Old coupe, old hemi, clutch pedal......... drag week.
You are a brave man!! 😎
Re: Drag Week 2018 [Re: fast68plymouth] #2543975
08/31/18 07:56 PM
08/31/18 07:56 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m betting Walmart won’t stock a lot of emergency spares for that one.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Drag Week 2018 [Re: JERICOGTX] #2543982
08/31/18 08:18 PM
08/31/18 08:18 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
There's a fine line between bravery and pure foolishness. I'm not yet sure which side of that line this absurdity sits on.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag Week 2018 [Re: Hemi_Joel] #2543983
08/31/18 08:26 PM
08/31/18 08:26 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
I have an antique by today's standards LC1 that could data log to a laptop serial port.(told you it was antique)
Does yours have USB or Bluetooth capability to interface with a phone, tablet or laptop? I think their datalogging software was called Logworks.
Kevin
Re: Drag Week 2018 [Re: Hemi_Joel] #2543984
08/31/18 08:31 PM
08/31/18 08:31 PM
So. Burlington, Vt.
So. Burlington, Vt.
I think you’ll know which side you’re on with that thing in the next couple weeks.
Either way, I’m looking forward to watching it go down the track on the live feeds.
Re: Drag Week 2018 [Re: JERICOGTX] #2543985
08/31/18 08:44 PM
08/31/18 08:44 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I think its crazy, but crazy and drag week go together just fine!
I still don't have a transmission in my car. I am hoping that is remedied tomorrow, and if not we will probably take the one from my Dad's car and put it in mine.
68 Barracuda Formula S 340
Re: Drag Week 2018 [Re: Twostick] #2543989
08/31/18 08:52 PM
08/31/18 08:52 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Kevin
I phoned Innovate to get the data logging capability of the MTX-l A/f ratio meter clarified. It comes with a serial cable that will connect it to a computer, but it will not store data. So it has to be connected to the computer while making the pass. I didn't like that idea, so I bought their #3875 pocket logger that will store and playback the A/F data without having to use a computer.
Re: Drag Week 2018 [Re: Hemi_Joel] #2544073
09/01/18 12:41 AM
09/01/18 12:41 AM
IL
furious70 Offline
furious70  Offline
IL
Kevin
In my Coronet I have their analog gauge so that I could at a glance know I was ok. It's really hard to get a good ground for it and the logger though so it read off a half step or so. For a visual that's ok, just lined a mark up to it so I could be sure I was at or on the right side of 'no holes in pistons'
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Drag Week 2018 [Re: JERICOGTX] #2544122
09/01/18 03:07 AM
09/01/18 03:07 AM
AZ
squirrel Offline
squirrel  Offline
AZ
you need a low voltage analog volt meter, with a fat needle that the GoPro can see smile
Great progress Joel, see you next weekend! hopefully we'll both have Hemis, but I still have a ways to go to have mine running.
Re: Drag Week 2018 [Re: JERICOGTX] #2544465
09/02/18 12:05 AM
09/02/18 12:05 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Squirrel, I HOPE you can bring your Hemi! I tested again today, at an 1/8 mile track. The ET's were nothing to write home about, but it got back into the trailer under its own power after 5 passes, so that's a good thing.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Drag Week 2018 [Re: JERICOGTX] #2544469
09/02/18 12:20 AM
09/02/18 12:20 AM
AZ
squirrel Offline
squirrel  Offline
AZ
great to hear that! I'm not quite that far...but it's possible I'll get mine running and driving, and bring it to Atlanta.
Re: Drag Week 2018 [Re: JERICOGTX] #2544471
09/02/18 12:25 AM
09/02/18 12:25 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I can't wait to see the coupe run Joel, or the Almost Funny Car Jim.
I got a trans in today and fit the new hood.
Re: Drag Week 2018 [Re: squirrel] #2545314
09/03/18 07:32 PM
09/03/18 07:32 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
It is running!
https://www.youtube.com/watch?v=hrGhxj7jA9Y&feature=youtu.be
Re: Drag Week 2018 [Re: JERICOGTX] #2545392
09/03/18 10:45 PM
09/03/18 10:45 PM
AZ
squirrel Offline
squirrel  Offline
AZ
yup, got it going! hopefully we can get it to drive ok, etc. Went for another little drive after fixing some stuff, found more stuff to fix. Working on the wheelie bars, fan shroud, etc right now.
https://www.youtube.com/watch?v=cgs5NLeeU3Q
Re: Drag Week 2018 [Re: JERICOGTX] #2545404
09/03/18 10:58 PM
09/03/18 10:58 PM
So. Burlington, Vt.
So. Burlington, Vt.
Sweet!!!
I am def impressed with the effort!!
Re: Drag Week 2018 [Re: JERICOGTX] #2545455
09/04/18 12:34 AM
09/04/18 12:34 AM
IL
furious70 Offline
furious70  Offline
IL
perfect christening in the rain!
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Drag Week 2018 [Re: JERICOGTX] #2545803
09/04/18 08:08 PM
09/04/18 08:08 PM
alaska,usa
9
9secondsatellite Offline
alaska,usa
My wife and I will come as spectators. we're looking forward to meeting some new racers and seeing the cars.
