Indy 360-2 builds #2543672
08/31/18 01:14 AM
08/31/18 01:14 AM
Willow Spring
dagohman Offline OP
dagohman  Offline OP
Willow Spring
I don't see many builds using theses heads. I was wondering how many on here have used them and results. I have a set that were on a 360. Im in the process of doing a 408, but am undecided if Ill use them or go a different route
Thanks for any input
Re: Indy 360-2 builds [Re: dagohman] #2543698
08/31/18 02:14 AM
08/31/18 02:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry I didnt use them but I assume this is on
a stock type of block.. I built a 408 from a
R3 block with W-9 heads
wave
Re: Indy 360-2 builds [Re: dagohman] #2543766
08/31/18 10:43 AM
08/31/18 10:43 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Depends on your plans. I had a pair ported and flowing 325cfm on a pump gas 408.Est HP was right around 580-590. 3300# 67 Barracuda ran 10.35@130 best. If i did it again would go a different direction. Edelbrock victor or W9.
Re: Indy 360-2 builds [Re: mopar dave] #2543846
08/31/18 01:25 PM
08/31/18 01:25 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Sorry I can’t help you. I have the Indy 360-1’s on mine.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Indy 360-2 builds [Re: dagohman] #2543882
08/31/18 03:08 PM
08/31/18 03:08 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
May be worth doing some digging,i think there where plenty of threads about them about 10 years ago.
Re: Indy 360-2 builds [Re: 1Fast340] #2543897
08/31/18 03:58 PM
08/31/18 03:58 PM
PA.
"Little"John
"Little"John
PA.
Porting on some of the Indy stuff scares the crap out of me. My 360-1’s were ported before I got them but never ran or on a flowbench. After I had them on my bench I knew there was more left and the exhaust side needed major work. I left more on the table that I will go after this winter on the intake side. The exhaust side were my biggest gains but I did have a small water leak so I removed them and welded it up. Best 1/4 mile has been a 9.42 and I’ve gone 6.001 three or four times. Still running a solid lifter cam
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Indy 360-2 builds [Re: dagohman] #2543914
08/31/18 04:42 PM
08/31/18 04:42 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I am running a set on my pump gas 394. They flow 337 @ .650. Motor made 662 hp at 7200 and 533 tq @ 5400. I still have not sorted it out. I only shift at 6800 and I don't have the timing turned up where it supposed to be (I am scared of the junk pump gas). And I built the headers which was the only set I have ever built.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Indy 360-2 builds [Re: dagohman] #2544158
09/01/18 10:12 AM
09/01/18 10:12 AM
K
KOS Offline
KOS  Offline
K
I've ran them too excellent heads....first on a 360/414 10.5comp piece that went 10.4s @3350lbs.then took same top end put em on a 13.1 436 R3 short same car down to 9.7s consistently.i really loved that motor went for 5-6yrs without a glitch.
Re: Indy 360-2 builds [Re: dagohman] #2544204
09/01/18 12:03 PM
09/01/18 12:03 PM
Willow Spring
dagohman Offline OP
dagohman  Offline OP
Willow Spring
Thanks for the replies. Im guessing you dont see many builds using them is due to more options that are cheaper now days.
My builds just a simple flat top, solid lifter bracket car.
I got the heads, just went through them last yr, all new valves, springs etc, might as well use them!!
Re: Indy 360-2 builds [Re: dagohman] #2544217
09/01/18 12:25 PM
09/01/18 12:25 PM
PA.
"Little"John
"Little"John
PA.
You won’t be sorry as long as they have been ported. None of these heads are very good unless they have been cnc’d or hand ported.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
