Re: Indy 360-2 builds
[Re: dagohman]
#2543698
08/31/18 02:14 AM
08/31/18 02:14 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Sorry I didnt use them but I assume this is on a stock type of block.. I built a 408 from a R3 block with W-9 heads
[Re: mopar dave]
#2543846
08/31/18 01:25 PM
08/31/18 01:25 PM
Posts: 20,175 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Sorry I can’t help you. I have the Indy 360-1’s on mine.
[Re: 1Fast340]
#2543897
08/31/18 03:58 PM
08/31/18 03:58 PM
Posts: 20,175 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Porting on some of the Indy stuff scares the crap out of me. My 360-1’s were ported before I got them but never ran or on a flowbench. After I had them on my bench I knew there was more left and the exhaust side needed major work. I left more on the table that I will go after this winter on the intake side. The exhaust side were my biggest gains but I did have a small water leak so I removed them and welded it up. Best 1/4 mile has been a 9.42 and I’ve gone 6.001 three or four times. Still running a solid lifter cam
[Re: dagohman]
#2543914
08/31/18 04:42 PM
08/31/18 04:42 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am running a set on my pump gas 394. They flow 337 @ .650. Motor made 662 hp at 7200 and 533 tq @ 5400. I still have not sorted it out. I only shift at 6800 and I don't have the timing turned up where it supposed to be (I am scared of the junk pump gas). And I built the headers which was the only set I have ever built.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: dagohman]
#2544217
09/01/18 12:25 PM
09/01/18 12:25 PM
Posts: 20,175 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You won’t be sorry as long as they have been ported. None of these heads are very good unless they have been cnc’d or hand ported.
