Page 5 of 5 1 2 3 4 5
Re: My new heads are killing me need help [Re: 70dusterjohn] #2541818
08/27/18 12:15 AM
08/27/18 12:15 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Check battery voltage/ charging system
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: My new heads are killing me need help [Re: 70dusterjohn] #2541889
08/27/18 08:57 AM
08/27/18 08:57 AM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
Cab I just use that expression I have no hair already !!
Re: My new heads are killing me need help [Re: Cab_Burge] #2542195
08/27/18 10:17 PM
08/27/18 10:17 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Originally Posted By Cab_Burge
Originally Posted By 70dusterjohn
It went 10.55 st 136 ? I just don’t get it . It comes out kinda flat and then really starts to come on. I went from a best 60ft of 1.28 to today a 1.75 ... I don’t know what to do at this point ..
It looks like converter time to me whiney Have it checked now before pulling all your hair out up whistling
time to go with a converter more compatable with your new combo, it may be only port work but it changed the characteristics of the motor and and the power range is in a higher rpm range.
Re: My new heads are killing me need help [Re: 70dusterjohn] #2542219
08/27/18 10:58 PM
08/27/18 10:58 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
283@.050, not a ton of compression, big heads, big intake....... I’d be looking for at least 5600 flash stall.
Re: My new heads are killing me need help [Re: fast68plymouth] #2542260
08/28/18 12:16 AM
08/28/18 12:16 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Put that thing on a dyno.. hopefully you can
find out what the engine problem is and get a
torque number for a converter.. right now it
sounds like your lost.. spend a bit now and
save yourself a pile later
wave
Re: My new heads are killing me need help [Re: 70dusterjohn] #2542347
08/28/18 09:21 AM
08/28/18 09:21 AM
Deerfield, Ohio
Deerfield, Ohio
I would love to put it on a dyno but it’s just not in the cards as I’m semi retired and still waiting on my cash flow to start . I believe I’m have a couple issues with it. One I didn’t jet it up at all after the head work, that’s fixed now. Second is the converter but it get work as I speak and I have an old J in there now, and third I think I’m at the power level that the shocks are going to need to be looked at .. I’m still running the 9000s that came with the kit ..
Re: My new heads are killing me need help [Re: 70dusterjohn] #2542372
08/28/18 10:53 AM
08/28/18 10:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a J conv in both of my cars.. the race
car is basically a stock J that stalls at 5600
rpm in my SB and the other is a J that I had
the stall dropped down to 4700 and the efficiency
is tightened up so it doesnt slip like stock..
that on is in my Rampage... both are 8"
wave
Re: My new heads are killing me need help [Re: 70dusterjohn] #2542688
08/28/18 07:45 PM
08/28/18 07:45 PM
Deerfield, Ohio
Deerfield, Ohio
Here’s a video going down the road .. the car was just spinning but none the less
https://youtu.be/ZL_aqLkF-N0
