Re: My new heads are killing me need help
[Re: 70dusterjohn]
#2541818
08/27/18 12:15 AM
08/27/18 12:15 AM
Posts: 11,727 Portage,michigan
B3422W5
Portage,michigan
Check battery voltage/ charging system
[Re: Cab_Burge]
#2542195
08/27/18 10:17 PM
08/27/18 10:17 PM
dartman366
Mt. Vernon, Ohio
It went 10.55 st 136 ? I just don’t get it . It comes out kinda flat and then really starts to come on. I went from a best 60ft of 1.28 to today a 1.75 ... I don’t know what to do at this point .. It looks like converter time to me Have it checked now before pulling all your hair out time to go with a converter more compatable with your new combo, it may be only port work but it changed the characteristics of the motor and and the power range is in a higher rpm range.
[Re: 70dusterjohn]
#2542219
08/27/18 10:58 PM
08/27/18 10:58 PM
fast68plymouth
So. Burlington, Vt.
283@.050, not a ton of compression, big heads, big intake....... I’d be looking for at least 5600 flash stall.
[Re: fast68plymouth]
#2542260
08/28/18 12:16 AM
08/28/18 12:16 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Put that thing on a dyno.. hopefully you can find out what the engine problem is and get a torque number for a converter.. right now it sounds like your lost.. spend a bit now and save yourself a pile later
[Re: 70dusterjohn]
#2542372
08/28/18 10:53 AM
08/28/18 10:53 AM
MR_P_BODY
I have a J conv in both of my cars.. the race car is basically a stock J that stalls at 5600 rpm in my SB and the other is a J that I had the stall dropped down to 4700 and the efficiency is tightened up so it doesnt slip like stock.. that on is in my Rampage... both are 8"
