Re: My new heads are killing me need help
[Re: a493demon]
#2540599
08/23/18 08:29 PM
08/23/18 08:29 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Prob. the dist pick up . If it's MSD I had one go out on mine . Checked wiring Checked timing Checked comp test 170-175 Checked leak down was not a noticeable difference Checked cap and rotor Checked crank trigger Checked ignition box/ tried my 7al
[Re: 70dusterjohn]
#2540786
08/24/18 09:31 AM
08/24/18 09:31 AM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
You have lost so much power, and right on the launch. That says it must be the ignition some how. Ther would be enuogh fuel in the bowls to carry you almost to the 60 ft clocks. Bad coil? Trigger wire picking up signal from another wire, poor conection, hopefully you do NOT have ignition wired any where through stock wiring. Coil wire have a break or bad connection?
[Re: tjmarcus1]
#2540790
08/24/18 09:47 AM
08/24/18 09:47 AM
Posts: 1,613 Deerfield, Ohio
70dusterjohn
Deerfield, Ohio
I am confused too! Is the motor in the car or out? Why did you not make a full pass? Was out put it back in. I put zippers on it so it’s easier 😂
[Re: gregsdart]
#2540792
08/24/18 09:49 AM
08/24/18 09:49 AM
70dusterjohn
Deerfield, Ohio
You have lost so much power, and right on the launch. That says it must be the ignition some how. Ther would be enuogh fuel in the bowls to carry you almost to the 60 ft clocks. Bad coil? Trigger wire picking up signal from another wire, poor conection, hopefully you do NOT have ignition wired any where through stock wiring. Coil wire have a break or bad connection? Was the msd box ..
[Re: 70dusterjohn]
#2541462
08/26/18 03:05 AM
08/26/18 03:05 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
Glad you found the problem, post the results
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: 70dusterjohn]
#2541742
08/26/18 09:17 PM
08/26/18 09:17 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Same as before 10.50's or same as before 9.70's? I thought that your G tech showed marked improvement. What changed since your street run the other day?
[image][/image]
[Re: 70dusterjohn]
#2541764
08/26/18 10:36 PM
08/26/18 10:36 PM
Posts: 4,457 Washington
madscientist
Washington
Look at the converter. Something is eating power.
I'd pull the engine and get it on the dyno to rule that out.
[Re: 70dusterjohn]
#2541804
08/26/18 11:40 PM
08/26/18 11:40 PM
sgcuda
136 mph? That's fast enough for a 9.70 pass. Something is wrong on the launch. The top end charge seems to be real strong. Carb, ignition, cam centerline?
[image][/image]
[Re: 70dusterjohn]
#2541814
08/27/18 12:08 AM
08/27/18 12:08 AM
Posts: 43,272 Bend,OR USA
Cab_Burge
It went 10.55 st 136 ? I just don’t get it . It comes out kinda flat and then really starts to come on. I went from a best 60ft of 1.28 to today a 1.75 ... I don’t know what to do at this point .. It looks like converter time to me Have it checked now before pulling all your hair out
