Cast tunnel rams on 500+ cube motors #2541432
08/26/18 12:02 AM
08/26/18 12:02 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
You guys that have done it, does your setup like carb spacers? I know the plenum sizes vary alot, even within the same brand. (I know Weiand has a scad of different plenum uppers.) Whats your setup like? I know Ill probably just have to try and see.
Re: Cast tunnel rams on 500+ cube motors [Re: Hot 340] #2541433
08/26/18 12:09 AM
08/26/18 12:09 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I think the Indy manifold has a larger plenum area than the Weiand. Weiand is an excellent choice. I have seen 1" and 2" spacers offered for sale to raise the plenum, but I have never used them, myself. I don't know if there is enough material to open up the Weiand for Max Wedge port size.
[image][/image]
Re: Cast tunnel rams on 500+ cube motors [Re: sgcuda] #2541437
08/26/18 12:18 AM
08/26/18 12:18 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Mine is for a hemi but I want to know what the wedge guys have seen as well. Its all applicable.
Re: Cast tunnel rams on 500+ cube motors [Re: Hot 340] #2541489
08/26/18 10:22 AM
08/26/18 10:22 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I've got a Weiand on my 605 Hemi and love it. I never tried any spacers under the carbs though as space between the carbs and the hood was real tight. It still makes tremendous torque and hp and I'd never consider going back to a single 4bbl.
Re: Cast tunnel rams on 500+ cube motors [Re: Hot 340] #2541629
08/26/18 04:50 PM
08/26/18 04:50 PM
A shed in England
Tig Online work
Tig  Online Work
A shed in England
We took the TR off our 655 and threw it on the 572 then threw the 572 in the car. The ports are mismatched (572 -13 v's 600 -13's), the hood isn't sealed, the carbs are too big (2 x 1150) but we've been within 1 MPH of the best the 572 has been with a single 4. We can't get it off the line yet (too many chassis changes) and the fueling isn't there either (lack of runs) When it all comes together I'm sure it will out run the single 4, which was a 440-3X with a well sorted out 1200 cfm pro systems dominator.
Re: Cast tunnel rams on 500+ cube motors [Re: Hot 340] #2541692
08/26/18 07:37 PM
08/26/18 07:37 PM
Every Mopar V8 motor, including SB, I've put larger carbs. on has gone faster and quicker shruggy
Every Hemiriod motors, especially 426 types, love more air and fuel up
As far as carb spacer you'll have to test yours to find the best combination up scope
Re: Cast tunnel rams on 500+ cube motors [Re: Hot 340] #2542139
08/27/18 08:02 PM
08/27/18 08:02 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Usually 1 in super sucker is the ticket ! (for me at least "")
Re: Cast tunnel rams on 500+ cube motors [Re: Hot 340] #2542255
08/28/18 12:05 AM
08/28/18 12:05 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I wonder how a shear plate would help on a tunnel ram?...
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Cast tunnel rams on 500+ cube motors [Re: Cab_Burge] #2542329
08/28/18 07:20 AM
08/28/18 07:20 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thanks guys. Ill experiment with spacers.
Re: Cast tunnel rams on 500+ cube motors [Re: Hot 340] #2542374
08/28/18 10:56 AM
08/28/18 10:56 AM
an8sec70cuda Offline
Back when I was considering a tunnelram for my 572 hemi, all I kept hearing was how small the plenums were. All the old Weiands were designed for near stock cube hemis, so they are on the small side for a 500+ inch motor.
As proven by quuickd100, they still make great power and a boatload of torque, but I bet his big hemi would make a bunch more power w/ a bigger manifold. I'd love to see him try something bigger b/c his motor is already a monster as it sits! Adding spacers should help, but it's gonna be awfully tall.
The Indy is the best cast hemi tunnelram, but even it will benefit from the plenum spacer that Indy offers on a 500+ cube motor.
I've played w/ all the big single 4500 manifolds on mine, but never tried a tunnelram. I had a 4500 flange Weiand for a while, but never bolted it on.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Cast tunnel rams on 500+ cube motors [Re: Hot 340] #2542834
08/29/18 12:50 AM
08/29/18 12:50 AM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
The tunnel ram probably doesn't weigh any more than one of those single planes too. I d love to try some spacers but I'd have to cut the hood and I won't do that.
Re: Cast tunnel rams on 500+ cube motors [Re: Hot 340] #2543017
08/29/18 01:55 PM
08/29/18 01:55 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have an Indy dual Dominator tunnel ram on my Hemi with a 1/2" white Nylon heat insulator spacer that I made between the manifold & top plate. I also have shear plates under the carbs as well..
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Cast tunnel rams on 500+ cube motors [Re: quickd100] #2543072
08/29/18 03:27 PM
08/29/18 03:27 PM
I wish I'd weighed the one I had, but never did. Sold it on ebay b/c I knew I'd never use it...wish I'd kept it for shelf jewelry if nothing else.
The Indy -3 and -4 single 4500 manifolds are about 23 to 25 lbs including the valley plate.
The Barton single 4500 manifold is 35 lbs!!!
CHIP
Re: Cast tunnel rams on 500+ cube motors [Re: Hot 340] #2543103
08/29/18 04:33 PM
08/29/18 04:33 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
If you end up needing an M1 dual 4bbl for an RB let me know
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Cast tunnel rams on 500+ cube motors [Re: Hot 340] #2545909
09/04/18 11:23 PM
09/04/18 11:23 PM
TEXAS
Panty Dropper Offline
TEXAS
I got a CFE Sheetmetal with 2-4 and 2 Speedtech foggers for sale on the sale page fir a B-1 if anyone's looking to GO FAST ! lol
