Re: Cast tunnel rams on 500+ cube motors
[Re: Hot 340]
#2541433
08/26/18 12:09 AM
08/26/18 12:09 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I think the Indy manifold has a larger plenum area than the Weiand. Weiand is an excellent choice. I have seen 1" and 2" spacers offered for sale to raise the plenum, but I have never used them, myself. I don't know if there is enough material to open up the Weiand for Max Wedge port size.
[image][/image]
[Re: sgcuda]
#2541437
08/26/18 12:18 AM
08/26/18 12:18 AM
Posts: 3,397 Pa
Hot 340
Pa
I think the Indy manifold has a larger plenum area than the Weiand. Weiand is an excellent choice. I have seen 1" and 2" spacers offered for sale to raise the plenum, but I have never used them, myself. I don't know if there is enough material to open up the Weiand for Max Wedge port size. Mine is for a hemi but I want to know what the wedge guys have seen as well. Its all applicable.
[Re: Hot 340]
#2541629
08/26/18 04:50 PM
08/26/18 04:50 PM
Posts: 2,937 A shed in England
Tig
A shed in England
We took the TR off our 655 and threw it on the 572 then threw the 572 in the car. The ports are mismatched (572 -13 v's 600 -13's), the hood isn't sealed, the carbs are too big (2 x 1150) but we've been within 1 MPH of the best the 572 has been with a single 4. We can't get it off the line yet (too many chassis changes) and the fueling isn't there either (lack of runs) When it all comes together I'm sure it will out run the single 4, which was a 440-3X with a well sorted out 1200 cfm pro systems dominator. ![](https://i.imgur.com/viinP9a.jpg)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Hot 340]
#2541692
08/26/18 07:37 PM
08/26/18 07:37 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
Every Mopar V8 motor, including SB, I've put larger carbs. on has gone faster and quicker ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Every Hemiriod motors, especially 426 types, love more air and fuel As far as carb spacer you'll have to test yours to find the best combination
[Re: Hot 340]
#2542255
08/28/18 12:05 AM
08/28/18 12:05 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I wonder how a shear plate would help on a tunnel ram?...
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Hot 340]
#2542374
08/28/18 10:56 AM
08/28/18 10:56 AM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
Back when I was considering a tunnelram for my 572 hemi, all I kept hearing was how small the plenums were. All the old Weiands were designed for near stock cube hemis, so they are on the small side for a 500+ inch motor. As proven by quuickd100, they still make great power and a boatload of torque, but I bet his big hemi would make a bunch more power w/ a bigger manifold. I'd love to see him try something bigger b/c his motor is already a monster as it sits! Adding spacers should help, but it's gonna be awfully tall.
The Indy is the best cast hemi tunnelram, but even it will benefit from the plenum spacer that Indy offers on a 500+ cube motor.
I've played w/ all the big single 4500 manifolds on mine, but never tried a tunnelram. I had a 4500 flange Weiand for a while, but never bolted it on.
[Re: Hot 340]
#2543017
08/29/18 01:55 PM
08/29/18 01:55 PM
Posts: 4,585 Motor City
6PKRTSE
Motor City
I have an Indy dual Dominator tunnel ram on my Hemi with a 1/2" white Nylon heat insulator spacer that I made between the manifold & top plate. I also have shear plates under the carbs as well..
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: quickd100]
#2543072
08/29/18 03:27 PM
08/29/18 03:27 PM
an8sec70cuda
The tunnel ram probably doesn't weigh any more than one of those single planes too. I d love to try some spacers but I'd have to cut the hood and I won't do that. I wish I'd weighed the one I had, but never did. Sold it on ebay b/c I knew I'd never use it...wish I'd kept it for shelf jewelry if nothing else. The Indy -3 and -4 single 4500 manifolds are about 23 to 25 lbs including the valley plate. The Barton single 4500 manifold is 35 lbs!!!
[Re: Hot 340]
#2543103
08/29/18 04:33 PM
08/29/18 04:33 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
If you end up needing an M1 dual 4bbl for an RB let me know
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: Hot 340]
#2545909
09/04/18 11:23 PM
09/04/18 11:23 PM
Posts: 70 TEXAS
Panty Dropper
TEXAS
I got a CFE Sheetmetal with 2-4 and 2 Speedtech foggers for sale on the sale page fir a B-1 if anyone's looking to GO FAST ! lol
