Will it hurt anything setting lash couple thou tighter
#2541970
08/27/18 12:15 PM
08/27/18 12:15 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Solid lifter cam Card calls for 22 hot Any problem trying 20 hot?
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Will it hurt anything setting lash couple thou tighter
[Re: B3422W5]
#2541972
08/27/18 12:16 PM
08/27/18 12:16 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
[Re: B3422W5]
#2542000
08/27/18 01:28 PM
08/27/18 01:28 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
As long as there is adequate v/p clearance you can run them as tight as you want.
When you get too far up the clearance ramp of the cam, the power will start falling off.
I often ran cams on “the big side”(for the application) in my own stuff, and they usually responded favorably to looser lash settings rather than tighter.
[Re: fast68plymouth]
#2542002
08/27/18 01:37 PM
08/27/18 01:37 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
It been awhile but I think I was down to .008-.010 on my aluminum block aluminum heads cold.
#2542003
08/27/18 01:40 PM
08/27/18 01:40 PM
B3422W5
Portage,michigan
I often ran cams on “the big side”(for the application) in my own stuff, and they usually responded favorably to looser lash settings rather than tighter. As you know, mine is definately one size too big. So figured next lash( this week) try little tighter
[Re: B3422W5]
#2542005
08/27/18 01:48 PM
08/27/18 01:48 PM
fast68plymouth
So. Burlington, Vt.
You feel it’s on the big side....... so you want to try making it bigger with tighter lash?
#2542014
08/27/18 02:12 PM
08/27/18 02:12 PM
B3422W5
Portage,michigan
You feel it’s on the big side....... so you want to try making it bigger with tighter lash? Your right. My thinking was the opposite of correct..... lol Tighter makes the cam bigger, looser, more clearance..... smaller. Shucks, darn it
[Re: B3422W5]
#2542018
08/27/18 02:22 PM
08/27/18 02:22 PM
fast68plymouth
So. Burlington, Vt.
Can’t hurt to try both........ might work, might not.
It’s like playing with jetting and timing....... just gotta find what it likes.
[Re: B3422W5]
#2542039
08/27/18 03:10 PM
08/27/18 03:10 PM
Posts: 4,206 New York
polyspheric
New York
If you guess wrong (too tight) on an exhaust valve, expect to pay for it.
Boffin Emeritus
[Re: B3422W5]
#2542055
08/27/18 03:32 PM
08/27/18 03:32 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Solid lifter cam Card calls for 22 hot Any problem trying 20 hot? Been setting em .008-.010 tighter forever..........My Isky solid roller calls for .026 hot and I've been setting em at .012-.014 cold forever and en up in the .020 hot zone..........
[Re: B3422W5]
#2542083
08/27/18 05:10 PM
08/27/18 05:10 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
I've only had a few solids, all in different motors. Two picked up with looser than recommended lash. The other was already at .030 and .028 per the manufacturer and tightening it slowed it down.
I theorized that my junk, with marginal to poor exhaust, tight converter, and shorter stroke generally performed better with less seat timing.
When you run the numbers, 0.004" might change seat timing 10°, but only change the 0.050" numbers by 3°. Kinda like making the ramps faster without changing the cam. Of course, its still a net smaller cam.
[Re: B3422W5]
#2542188
08/27/18 09:54 PM
08/27/18 09:54 PM
polyspheric
New York
How would it change the .050" at all?
Boffin Emeritus
[Re: Thumperdart]
#2542194
08/27/18 10:08 PM
08/27/18 10:08 PM
dartman366
Mt. Vernon, Ohio
Solid lifter cam Card calls for 22 hot Any problem trying 20 hot? Been setting em .008-.010 tighter forever..........My Isky solid roller calls for .026 hot and I've been setting em at .012-.014 cold forever and en up in the .020 hot zone.......... ^^^this
[Re: polyspheric]
#2542267
08/28/18 12:28 AM
08/28/18 12:28 AM
BSB67
Prospect, PA
How would it change the .050" at all? At the valve it will. Your an awful smart guy to ask such a question.
