Will it hurt anything setting lash couple thou tighter #2541970
08/27/18 12:15 PM
08/27/18 12:15 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Solid lifter cam
Card calls for 22 hot
Any problem trying 20 hot?
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Will it hurt anything setting lash couple thou tighter [Re: B3422W5] #2541972
08/27/18 12:16 PM
08/27/18 12:16 PM
an8sec70cuda Offline
nope
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Will it hurt anything setting lash couple thou tighter [Re: B3422W5] #2541977
08/27/18 12:23 PM
08/27/18 12:23 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
What he said^^
Re: Will it hurt anything setting lash couple thou tighter [Re: B3422W5] #2541991
08/27/18 01:08 PM
08/27/18 01:08 PM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
Curious as to how tight (from reccomended) is too tight? A friend asked me this same question a couple of days ago. I don't have any testing to back any of my thoughts, so I advised him to follow the manufacturer's card. How much power can be picked up by tightening the lash? A couple of HP??
Re: Will it hurt anything setting lash couple thou tighter [Re: B3422W5] #2542000
08/27/18 01:28 PM
08/27/18 01:28 PM
So. Burlington, Vt.
So. Burlington, Vt.
As long as there is adequate v/p clearance you can run them as tight as you want.
When you get too far up the clearance ramp of the cam, the power will start falling off.
I often ran cams on “the big side”(for the application) in my own stuff, and they usually responded favorably to looser lash settings rather than tighter.
Re: Will it hurt anything setting lash couple thou tighter [Re: fast68plymouth] #2542002
08/27/18 01:37 PM
08/27/18 01:37 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
It been awhile but I think I was down to .008-.010 on my aluminum block aluminum heads cold.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Will it hurt anything setting lash couple thou tighter [Re: fast68plymouth] #2542003
08/27/18 01:40 PM
08/27/18 01:40 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
As you know, mine is definately one size too big. So figured next lash( this week) try little tighter
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Will it hurt anything setting lash couple thou tighter [Re: B3422W5] #2542005
08/27/18 01:48 PM
08/27/18 01:48 PM
So. Burlington, Vt.
So. Burlington, Vt.
You feel it’s on the big side....... so you want to try making it bigger with tighter lash?
Re: Will it hurt anything setting lash couple thou tighter [Re: fast68plymouth] #2542014
08/27/18 02:12 PM
08/27/18 02:12 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Your right. My thinking was the opposite of correct..... lol
Tighter makes the cam bigger, looser, more clearance..... smaller. Shucks, darn it
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Will it hurt anything setting lash couple thou tighter [Re: B3422W5] #2542018
08/27/18 02:22 PM
08/27/18 02:22 PM
So. Burlington, Vt.
So. Burlington, Vt.
Can’t hurt to try both........ might work, might not.
It’s like playing with jetting and timing....... just gotta find what it likes.
Re: Will it hurt anything setting lash couple thou tighter [Re: fast68plymouth] #2542029
08/27/18 02:53 PM
08/27/18 02:53 PM
iagree
You have to test each combination, one thing at a time, to find out what your motor and car wants scope up
Re: Will it hurt anything setting lash couple thou tighter [Re: B3422W5] #2542039
08/27/18 03:10 PM
08/27/18 03:10 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If you guess wrong (too tight) on an exhaust valve, expect to pay for it.
Boffin Emeritus
Re: Will it hurt anything setting lash couple thou tighter [Re: B3422W5] #2542055
08/27/18 03:32 PM
08/27/18 03:32 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By B3422W5
Solid lifter cam
Been setting em .008-.010 tighter forever..........My Isky solid roller calls for .026 hot and I've been setting em at .012-.014 cold forever and en up in the .020 hot zone.......... beer
Re: Will it hurt anything setting lash couple thou tighter [Re: B3422W5] #2542083
08/27/18 05:10 PM
08/27/18 05:10 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I've only had a few solids, all in different motors. Two picked up with looser than recommended lash. The other was already at .030 and .028 per the manufacturer and tightening it slowed it down.
I theorized that my junk, with marginal to poor exhaust, tight converter, and shorter stroke generally performed better with less seat timing.
When you run the numbers, 0.004" might change seat timing 10°, but only change the 0.050" numbers by 3°. Kinda like making the ramps faster without changing the cam. Of course, its still a net smaller cam.
Re: Will it hurt anything setting lash couple thou tighter [Re: B3422W5] #2542188
08/27/18 09:54 PM
08/27/18 09:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
How would it change the .050" at all?
Boffin Emeritus
Re: Will it hurt anything setting lash couple thou tighter [Re: Thumperdart] #2542194
08/27/18 10:08 PM
08/27/18 10:08 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Solid lifter cam
^^^this coffee
Re: Will it hurt anything setting lash couple thou tighter [Re: polyspheric] #2542267
08/28/18 12:28 AM
08/28/18 12:28 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
At the valve it will. Your an awful smart guy to ask such a question.
