Mixing Rockers in a W2 Head #2539649
08/21/18 04:21 PM
08/21/18 04:21 PM
Mequon, WI
gzig5 Offline OP
gzig5  Offline OP
Mequon, WI
I've found a set of iron W2 non-roller rockers for a very attractive price that should work nicely with the Econo heads I'm looking at getting. Of course the price is attractive because the set is missing one of the intake rockers, a Right I think. I'm starting to look for the unicorn single right iron rocker for sale at a reasonable price. But I've seen single roller rockers here and there before on ebay. Is there any reason I can't run a one roller tip rocker and the rest solid iron if I can find a single? I'd love to just dump $1100+ into a new set of roller rockers but my project becomes much more viable if I spend the ~$900 difference elsewhere.
Re: Mixing Rockers in a W2 Head [Re: gzig5] #2539656
08/21/18 04:39 PM
08/21/18 04:39 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Can't think of one, as long as widths are the same. Crane sold individual Golds at on time May still. I have a NOS 69750-1 exhaust here. May have a couple of used intakes I had for spares. Will have to look.
Re: Mixing Rockers in a W2 Head [Re: gzig5] #2539663
08/21/18 04:59 PM
08/21/18 04:59 PM
Washington
madscientist Offline
Washington
You will have one rocker that requires different geometry corrections than the other 15. I wouldn't do it. I'd not have much trouble mixing different roller rockers if and its a big IF they were exactly the same.
You can have different rockers that all require different geometry.
Re: Mixing Rockers in a W2 Head [Re: gzig5] #2539728
08/21/18 07:01 PM
08/21/18 07:01 PM
P
Porter67 Offline
Porter67  Offline
P
Id have to adjust my thinking on the whole purchase, the one main issue with even the best old outdated related parts weather a rocker or a piston is if you hurt one you in a pickle. looking for a replacement.
Maybe try to buy the heads without the rockers or you could even buy them and sell them as singles and purchase a new set.
But with all that, id bet if you looked hard enough you probably could find a matching single rocker.
Re: Mixing Rockers in a W2 Head [Re: Porter67] #2539740
08/21/18 07:16 PM
08/21/18 07:16 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Member Jack Moore used to advertise W2 rockers for sale quit often. You might want to get ahold of him. He’s from the Columbus Ohio area and I think he goes by Moore and Moore on Moparts
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Mixing Rockers in a W2 Head [Re: gzig5] #2539745
08/21/18 07:41 PM
08/21/18 07:41 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Bill Evans ( http://www.evanswiring.com/ )
Had some singles in a box at Carlisle, 20 bucks a piece.
Re: Mixing Rockers in a W2 Head [Re: Porter67] #2540139
08/22/18 07:36 PM
08/22/18 07:36 PM
Mequon, WI
gzig5 Offline OP
gzig5  Offline OP
Mequon, WI
Rockers and heads are coming from separate sources. A local shop has an unused set of large chamber Econo heads at a great price. I haven't committed to taking them until I can source a set of rockers at a reasonable (to me) cost. I'm working with a really tight budget and the car needs many things so I need to keep the total cost as low as possible to make the swap feasible. I like the idea of the potential the W2 heads hold over the current options. Downsides to them too regarding intakes and header selection. If these rockers work out, I think I can get the heads setup and ready to run for somewhere between $1500-$1700 depending on valves/springs and machining costs.
I wish the Trick Flows would announce pricing and get them out there to see if I want to go that way.
I'll contact Mr. Evans and Mr. Moore to see if they can help me out. Thanks!
Re: Mixing Rockers in a W2 Head [Re: gzig5] #2540151
08/22/18 08:07 PM
08/22/18 08:07 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Will the rockers for Indy 360-1 heads fit W-2's? If so I have a complete set that came with my heads.
Re: Mixing Rockers in a W2 Head [Re: gzig5] #2540154
08/22/18 08:14 PM
08/22/18 08:14 PM
Washington
Washington
I have a friend with a complete set of NIB W-2 bushed rockers and brand new shafts. If you want I'll check with him and see what he wants for the stuff.
PM me if you are interested.
Re: Mixing Rockers in a W2 Head [Re: gzig5] #2540158
08/22/18 08:25 PM
08/22/18 08:25 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I will suggest sending a photo of the exact type you need with your request, the box he had was mixed lefts & rights with TA rockers mixed in the same box.
Re: Mixing Rockers in a W2 Head [Re: Alaskan_TA] #2540330
08/23/18 10:29 AM
08/23/18 10:29 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A pic would be great.. I have about 10 econo
rockers kicking around(spares) I also have a
some of the blue MP econo rockers.. might have
a few TD single shaft and a few econo multi
shaft ones but on those you need to mill the
rocker stands... but take a pic.. that makes
life so much easier
wave
Re: Mixing Rockers in a W2 Head [Re: gzig5] #2540373
08/23/18 11:45 AM
08/23/18 11:45 AM
Mequon, WI
gzig5 Offline OP
gzig5  Offline OP
Mequon, WI
I've got a pic, but I can't get to any hosting sites through our firewall. Don't see any option to upload from computer. I can send it via email if someone will post it, or I'll try to figure out one of the hosting sites since photobucket went nutz.
Pic
Did that work? I see it but does anyone else
Re: Mixing Rockers in a W2 Head [Re: gzig5] #2540562
08/23/18 06:58 PM
08/23/18 06:58 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It worked.
Re: Mixing Rockers in a W2 Head [Re: gzig5] #2540597
08/23/18 08:10 PM
08/23/18 08:10 PM
Washington
Washington
Those are the bushed rockers. Could have been bushed after the fact. That was the different between the race rocker and the econo rocker. The race rocker was bushed.
IMO, they all should have been bushed.
Re: Mixing Rockers in a W2 Head [Re: madscientist] #2540609
08/23/18 09:09 PM
08/23/18 09:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sorry cant help ya.. I've never had a iron rocker
wave
Re: Mixing Rockers in a W2 Head [Re: madscientist] #2540635
08/23/18 10:32 PM
08/23/18 10:32 PM
Mequon, WI
gzig5 Offline OP
gzig5  Offline OP
Mequon, WI
That is good to know. I'm learning a lot.
Other than the bushing are the dimensions the same between the race and Econo versions? 1.5 ratio?
Re: Mixing Rockers in a W2 Head [Re: gzig5] #2540654
08/23/18 11:17 PM
08/23/18 11:17 PM
Washington
Washington
Yes.
Re: Mixing Rockers in a W2 Head [Re: gzig5] #2540667
08/23/18 11:48 PM
08/23/18 11:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Also.. are your econo heads, long valve or the
standard.. they use different rockers.. MP messed
up and sent one of each heads.. took me a while
to figure out why I couldnt get the geometry right
on the standard head with the long valve rockers
on that head.. both were meant to be long valve
wave
Re: Mixing Rockers in a W2 Head [Re: MR_P_BODY] #2540689
08/24/18 12:37 AM
08/24/18 12:37 AM
Washington
Washington
wave
So the saddles were different heights between the two heads?
Re: Mixing Rockers in a W2 Head [Re: madscientist] #2540699
08/24/18 12:58 AM
08/24/18 12:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
up and sent one of each heads.. took me rockers
wave
a while
Yep.. I dont recall the diff at the moment but
they are different heights.. Mopar screwed me on
that set of heads.. weighted 9 months for them
and one set was all wrong.. it had a hole in it
that I had to fix(was in the oil area.. easy job
to fix.. braised it up)
wave
