Lokar Kick Down questions for 727 **** UPDATE***** #2540031
08/22/18 02:37 PM
08/22/18 02:37 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Anyone using this setup for their car? What's your thoughts on it's operation? I can't get my stock style rod set-up to work properly on a 72 400 with a Holley Carburetor and TM-6.
I'm either too far from instant contact or making the rod move too far resulting in no full throttle.
Any pictures of a Lokar on a bigblock and Holley at the carburetor would be helpful so I see how it looks.
Ron
Re: Lokar Kick Down questions for 727 [Re: RJS] #2540033
08/22/18 02:47 PM
08/22/18 02:47 PM
New York
rarefish Offline
rarefish  Offline
New York
If the carb sits higher on your new intake then it did with the stock intake then your factory kick down linkage will not usually work. That when the cable set up comes in handy.
Here is a pic of the Lokar kick down cable and throttle cable on my 440 with a Eddie Performer RPM intake and a Eddie Performer carb.
Re: Lokar Kick Down questions for 727 [Re: rarefish] #2540043
08/22/18 02:59 PM
08/22/18 02:59 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Thank you for your response and picture!!
I would assume I can still use my stock Throttle cable and bracket since the Lokar kickdown bolts to carburetor base??
Ron
Re: Lokar Kick Down questions for 727 [Re: RJS] #2540089
08/22/18 04:58 PM
08/22/18 04:58 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Ron,
I did some work a few years ago on a 69 Hemi Roadrunner clone ( single 4 barrel carb ) and installed the Lokar setup. I dont remember any issues .
I cant remember if I used the stock Mopar throttle cable or not( this was maybe 6 or 7 years ago )
Re: Lokar Kick Down questions for 727 [Re: RJS] #2540105
08/22/18 05:31 PM
08/22/18 05:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I'm an outspoken critic of the Lokar cable when installed using their directions.
The problem with the Lokar is that it's generic even when advertised to fit a Mopar because of the different lengths of the factory transmission lever.
If the generic Lokar instructions are followed and the cable adjusted so that the trans lever is full back at carb WOT you can see (simple math) that the first 3/4" to 1 1/2" of the lever travel is already used up at idle and there's no spring to pull the lever forward.
It's not unusual to see these Lokar installations have light throttle 1-2 shifts at 25+ mph and 2-3 at 40+ mph or even higher and, possibly, no 2-3 upshift at all. If the cable is adjusted for correct light throttle shift points there is insufficient TP at WOT and no forced downshifts. Potential damage.
So, as I've repeatedly ranted, the Lokar works OK if the installer ignores the Lokar adjustment procedure and knows to match the total travel of the cable attach points and installs a spring.
You need to measure the full travel of the carb lever where the cable attaches and then measure the full travel of the transmission lever where the cable attaches; it usually won't be the same so you need to drill a new hole in the transmission lever so that the full travel of both levers is the same. Also, there should be a spring pulling the transmission lever forward.
It isn't necessary for the trans lever to be full back at WOT but be sure that WOT under the hood is the same as WOT at the pedal...misadjusted throttle linkage will prevent the carb from going wide open when the pedal is matted and that, in turn, will prevent the trans lever from going back enough to provide kickdown.
Remove the cable from the carb and measure how far the hole in the throttle lever moves from idle to WOT. Then measure how far the hole in the trans lever moves from full forward to full back. The movement of the trans lever will likely be more than the carb lever so find the spot on the trans lever that matches the travel of the carb lever and drill there.
It's unlikely that the trans lever will return to the full forward position without a spring assist.
Re: Lokar Kick Down questions for 727 [Re: John_Kunkel] #2540136
08/22/18 07:22 PM
08/22/18 07:22 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
John I appreciate your input on this subject. I am very hesitant to go with this set-up because of the visual differences underhood also. With that said it sounds like I'd be better off doing the math you describe and then just use my factory rod no?
Thanks Ron
Re: Lokar Kick Down questions for 727 [Re: RJS] #2540152
08/22/18 08:12 PM
08/22/18 08:12 PM
usa
Mopar1970440 Offline
usa
Ive had the lokar cables on a few different cars..personally I didn't like the looks or the process of setting them up. I loved it when I went to manual valve bodys and was able to remove them.
Re: Lokar Kick Down questions for 727 [Re: RJS] #2540160
08/22/18 08:30 PM
08/22/18 08:30 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Bouchillon has the best set up, they have the correct ratio for a mopar.
CLICK HERE
Re: Lokar Kick Down questions for 727 [Re: RJS] #2540162
08/22/18 08:35 PM
08/22/18 08:35 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I think if you do a little research you find a big preference with Bouchillon over Lokar. twocents
Re: Lokar Kick Down questions for 727 [Re: CSK] #2540164
08/22/18 08:38 PM
08/22/18 08:38 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
CLICK HERE
Didn't know that one existed, thanks for the information!!
Just went through the Boochillon instructions and like what I see, they have covered all my concerns!!
Ron
Re: Lokar Kick Down questions for 727 [Re: 62maxwgn] #2540167
08/22/18 08:53 PM
08/22/18 08:53 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Yep Bill looks to be well thought out!!
Ron
Re: Lokar Kick Down questions for 727 [Re: RJS] #2540177
08/22/18 09:04 PM
08/22/18 09:04 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Yes the Bouchillon setup works great.
Have it on my 727 in my Jeep CJ7 and works , set it once and forgot about it
switched from carb to fitech and didn't even need to mess with it
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Lokar Kick Down questions for 727 [Re: Mopar1970440] #2540191
08/22/18 09:35 PM
08/22/18 09:35 PM
oklahoma
forphorty Online content
forphorty  Online Content
oklahoma
I bought my first manual valve body over 25 years ago. I have two cars currently with them and a project car that will have one when it hits the road. Will never go back to automatic function.
Re: Lokar Kick Down questions for 727 [Re: moparts] #2540235
08/22/18 11:42 PM
08/22/18 11:42 PM
BDW Online content
BDW  Online Content
Same here, Bouchillon set-up is a little spendy, but it works.
Re: Lokar Kick Down questions for 727 [Re: BDW] #2540237
08/22/18 11:45 PM
08/22/18 11:45 PM
JERSEY
RJS Offline OP
RJS  Offline OP
JERSEY
Just ordered up the Bouchchillon kit tonight, thanks to everyone that helped me out with this!!
Ron
Re: Lokar Kick Down questions for 727 [Re: RJS] #2540317
08/23/18 09:01 AM
08/23/18 09:01 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Ron
You won't be disappointed. I used their kit when I had my 69 Wagon that I put a 440/727 in. I am not a mechanic, more of a tinkerer and I followed the instructions and was very pleased.
Scott
1969 Super Bee, 383/4 speed
Re: Lokar Kick Down questions for 727 [Re: StukaJU87] #2540380
08/23/18 11:58 AM
08/23/18 11:58 AM
New York
rarefish Offline
rarefish  Offline
New York
John Kunkel has it right when it comes to the Lokar kick down cable. I installed a Lokar cable in my 64 440 Belvedere 18 years ago. I followed their install instructions, but was always dealing with a late 2-3 shift.
After reading some of his prior posts here, I finally did something about it earlier this year.
First I drilled a new hole to relocated the cable attaching point on the transmission lever inward about 1". I also added a return spring that I installed in the original hole that the cable previously attached to.
A big improvement was realized. I finally have a transmission that shifts correctly.
Re: Lokar Kick Down questions for 727 [Re: rarefish] #2540388
08/23/18 12:18 PM
08/23/18 12:18 PM
moparx Offline
moparx  Offline
i'm another one against the lokar setup. i have personally removed over a dozen of those junk pieces, and either reverted back to modified stock setups, bouchillon kits, or manual valve bodies. if you want to use bicycle cable, go to the hardware store. the brackets are junk and bend super easy during use. and as john said, their instructions are worthless. buyer beware !
beer
Re: Lokar Kick Down questions for 727 [Re: CSK] #2540433
08/23/18 01:48 PM
08/23/18 01:48 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
CLICK HERE
Thanks John & Ron for your best advice for the linkage problem! Looks like I'll be changing the (expensive), non factory looking setup for my new D100 we're finishing & its 383 we've rebuilt.. and I'll also be getting Bouchellon's kit for my 71 W100's new motor that's almost done. I had the Lokar setup on the W100's orikg 383 for years & used it for the D100, so NOW I'll be replacing both with correct setups. Sure appreciate this post.
Re: Lokar Kick Down questions for 727 [Re: Triggerfish] #2540440
08/23/18 02:11 PM
08/23/18 02:11 PM
moparx Offline
moparx  Offline
really GREAT looking truck ! i likey a lot ! up
beer
